PRV Audio 10W600 10" High Power PA Woofer 8 Ohm
Brand:|Model: 10W600|Part # 294-2720
The do-it-all PRV Audio 10W600 10" woofer is the right choice for use as a woofer, midrange, midbass, or guitar speaker.
  • Versatile design can be used as a woofer, midbass, or midrange
  • Works well as a guitar speaker
  • 2.5" diameter voice coil for high power handling
PRV Audio's 10W600 10" professional audio woofer is the embodiment of a true workhorse. Use it as a woofer in two-way speakers, a midrange or midbass in large format three-way speakers... the extended frequency response even allows this driver to be used as a guitar speaker!
What sets this speaker apart from other budget 10" woofers is the use of a 2.5" diameter voice coil and the generous 5.5 mm of Xmax. A stamped steel frame is used to handle abuse while keeping the speaker light. A paper cone combined with a woven cloth surround enables decent sensitivity and creates a natural sound.
  • Nominal Diameter10"
  • Power Handling (RMS)300 Watts
  • Power Handling (max)600 Watts
  • Impedance8 ohms
  • Frequency Response56 to 2,500 Hz
  • Sensitivity94 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)57.2 Hz
  • DC Resistance (Re)6.2 ohms
  • Mechanical Q (Qms)11.08
  • Electromagnetic Q (Qes)0.98
  • Total Q (Qts)0.90
  • Compliance Equivalent Volume (Vas)0.97 ft.³
  • BL Product (BL)10.37 Tm
  • Diaphragm Mass Inc. Airload (Mms)47.05g
  • Maximum Linear Excursion (Xmax)5.5 mm
  • Surface Area of Cone (Sd)363 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.1"
  • Baffle Cutout Diameter9.25"
  • Depth4.21"
  • # Mounting Holes8
  • Sealed Volume2.38 ft.³
  • Sealed F355 Hz
  • Vented Volume4.89 ft.³
  • Vented F333 Hz
  • BrandPRV Audio
  • Model10W600
  • Part Number294-2720
  • UPC799928733687
    (1 Reviews)
  • Weight7.95 lbs.
View similar products to the PRV Audio 10W600 10" High Power PA Woofer 8 Ohm
