PRV Audio 10MB800 10" High Power PA Midbass Woofer 8 Ohm
Brand:|Model: 10MB800|Part # 294-2722
PRV Audio's 10MB800 features a high sensitivity design combined with a cast aluminum frame. Use the 10MB800 as a midbass and midrange in pro audio 3-way cabinets or as a woofer in small ported monitors. The most powerful 10" midbass in the PRV Audio line is great for high SPL car audio systems.
List Price$162.38
You Save29%
$115.99
Part # 294-2722
  • Midbass or midrange for pro audio and high SPL car audio systems
  • Dual spider and M-Roll surround for accuracy
  • Strong, yet lightweight cast aluminum frame
  • Designed to be used as a woofer in small ported cabinets
  • 2.5" aluminum voice coil with 400W RMS power handling
The 10MB800 10" PRV Audio midbass woofer is the most powerful 10" midbass loudspeaker in the PRV Audio line. A cast aluminum frame is used for extreme durability, and the 10MB800 can be used as a midbass or midrange driver in 3-way speakers. Alternatively, you can use this speaker in small ported cabinets as a woofer in floor and studio monitors.
Dynamic, punchy midbass is generated from the sensitive 400W RMS power handling motor design that features a 2.5" aluminum voice coil former. Two durable woven spiders (coated with a special resin) are combined with a treated cotton M-Roll surround for accurate travel, and a thick, rigid paper cone for years of trouble-free operation, even in the most demanding high SPL car audio systems.
  • Nominal Diameter10"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance8 ohms
  • Frequency Response59 to 3,500 Hz
  • Sensitivity95 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)65.27 Hz
  • DC Resistance (Re)6.59 ohms
  • Voice Coil Inductance (Le)1.64 mH
  • Mechanical Q (Qms)3.11
  • Electromagnetic Q (Qes)0.39
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.90 ft.³
  • BL Product (BL)17.44 Tm
  • Diaphragm Mass Inc. Airload (Mms)44.60g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)369.8 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.3"
  • Baffle Cutout Diameter9.06"
  • Depth3.91"
  • # Mounting Holes8
  • Sealed Volume0.39 ft.³
  • Sealed F3123 Hz
  • Vented Volume0.93 ft.³
  • Vented F368 Hz
  • BrandPRV Audio
  • Model10MB800
  • Part Number294-2722
  • UPC799928733663
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight12.5 lbs.
View similar products to the PRV Audio 10MB800 10" High Power PA Midbass Woofer 8 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
is there a recone kit for this speaker
Asked by: Terry1
We do not have a re cone kit available for this model.
Date published: 2014-10-20
Why is the prv 10 inch 10pmb800 manufacturer spec sheet different from the front page on your website. states resonant freq. is different
Asked by: ChrisD
It appears our website is incorrect, I will have this updated to match the PRV spec sheet.
Date published: 2013-02-11
  • 2016-02-10T07:22CST
  • loc_en_US, sid_294-2722, PRD, sort_recentQuestionsFirst
