PRV Audio 10MB500 10" High Power PA Midbass Woofer 8 Ohm
Brand:|Model: 10MB500|Part # 294-2721
Extreme power handling and punchy midbass are the hallmarks of PRV Audio's 10MB500. A great choice for professional 3-way cabinets, floor and studio monitors, even for use in high SPL mobile audio systems.
  • Great choice for pro audio and high SPL car audio systems
  • Smooth midrange combined with strong midbass punch
  • Strong cast aluminum frame
  • Designed for small ported cabinets when used as a woofer
  • 225W RMS power handling
PRV Audio's 10MB500 10" midbass woofer offers high output punch, a smooth midrange, and response up to 4,000 Hz. The 10MB500 is designed for use as a midbass or midrange driver in 3-way speakers. Alternatively, you can use this speaker in small ported cabinets as a woofer in floor and studio monitors.
A thick, light, and rigid paper cone is mated to a 2.5" Kapton® voice coil former for great sensitivity and high power handling. A durable spider suspension, M-Roll woven cotton surround, and cast aluminum frame are combined for extreme durability. High output SPL car audio enthusiasts gravitate towards this driver for use in their systems when looking for a midrange or midbass that can sustain long hours of extreme operation.
  • Nominal Diameter10"
  • Power Handling (RMS)250 Watts
  • Power Handling (max)500 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity97.5 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)50.47 Hz
  • DC Resistance (Re)6.67 ohms
  • Voice Coil Inductance (Le)1.53 mH
  • Mechanical Q (Qms)2.05
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)1.63 ft.³
  • BL Product (BL)15.05 Tm
  • Diaphragm Mass Inc. Airload (Mms)39.83g
  • Maximum Linear Excursion (Xmax)4.3 mm
  • Surface Area of Cone (Sd)363.10 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.5"
  • Baffle Cutout Diameter9.1"
  • Depth4.1"
  • # Mounting Holes8
  • Sealed Volume0.43 ft.³
  • Sealed F3107 Hz
  • Vented Volume0.99 ft.³
  • Vented F362 Hz
  • BrandPRV Audio
  • Model10MB500
  • Part Number294-2721
  • UPC799928733670
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight11.55 lbs.
View similar products to the PRV Audio 10MB500 10" High Power PA Midbass Woofer 8 Ohm
