361-630_ALT_0
ProVision PV100 Borescope 18" 10.5mm Obedient Shaft
Brand:|Model: PV100|Part # 361-630
The ProVision PV100 borescope features the same performance as borescopes that cost up to 10 times as much. Innovative fiber optics run the entire length of an adjustable shaft that bends in any direction to allow for precise viewing.
  • Useful for mechanics, electricians, home inspectors, and law enforcement officers
  • 18" long, 0.4" diameter obedient cable maintains its position until readjusted
  • Same high performance of borescopes costing up to 10 times more
  • Pressure activated light cannot be accidentally left on
Borescopes are used for the inspection of inaccessible areas. Innovative fiber optic technology runs the entire length of an adjustable, flexible shaft that bends in any direction to allow for precise viewing. The ProVision PV100 borescope features the same performance as borescopes that cost up to 10 times as much. Features of the PV100 include an ergonomically designed, non-slip handle for single-handed operation, and an integrated focus ring helps to provide a clear image through the high resolution lens with a wide 40° field-of-view on objects as close as 3/4" away from the tip. Also, the 18" obedient cable of the PV100 maintains a fixed position until it's readjusted, and is 0.4" (10.5 mm) in diameter to fit inside of holes 1/2" and larger. A pressure activated light switch is conveniently located on the handle and cannot be accidentally left on.
  • BrandProVision
  • ModelPV100
  • Part Number361-630
  • UPC768249122340
  • Product CategoryWall Scopes & Inspection Cameras
    (1 Reviews)
  • Weight2 lbs.
View similar products to the ProVision PV100 Borescope 18" 10.5mm Obedient Shaft
in the Wall Scopes & Inspection Cameras product category.
