ProMounts UF-PRO400B 60"-100" Fixed TV Wall Mount
Brand:|Model: UF-PRO400B|Part # 185-632
The ProMounts UF-PRO400B Fixed TV Wall Mount supports flat panel screens TV displays between 60" and 100", and weighing up to 400 lbs.
List Price$249.95
You Save32%
$169.95
Part # 185-632
  • Holds the largest screens, maximum load capacity of 400 lbs.
  • Fully assembled mounting plate
  • Slim design only 1.5" deep but leaves room for cabling
  • Universal—does not require a screen adapter
  • Compliant with all VESA standards
  • Screen and wall mounting hardware included
  • Includes security hardware and accepts padlocks
Patent pending V-Bar technology makes it possible for the ProMounts UF-PRO400B Fixed TV Wall Mount to support the largest flat panel screens, easily and securely. Its V-Bar design also enables fast, simple horizontal and vertical adjustments to the screen, even after the installation.
The largest displays are no problem for the UF-PRO400B—it accommodates TVs between 60" and 100", up to 400 lbs., yet fits as close as 1.5" from the wall. The included hardware attaches to three or four studs spaced up to 52" apart, and concrete or aggregate walls.
Specifications: • Maximum load: 400.00 lbs. • TV size: between 60" and 100" • Horizontal hole spacing: between 2.95" and 2.95" • Vertical hole spacing: between 2.95" and 28.89".
  • Mount TypeFixed
  • Mount StyleWall Mount
  • TV Capacity60" to 69",70" and up
  • BrandProMounts
  • ModelUF-PRO400B
  • Part Number185-632
  • UPC856476001221
  • Product CategoryTV Mounts & Brackets
    (1 Reviews)
  • Weight18 lbs.
ProMounts UF-PRO400B 60"-100" Fixed TV Wall Mount is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Good product easy instructionsQuick shipping easy to hang. Only problem was the locks, you can't get to them because the tv is so close to the wall. It's not going to fall unless there is an earthquake.
Date published: 2014-07-30
  • 2016-02-06T07:16CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_185-632, PRD, sort_mostRecent
WIll this work on a Samsung 650ts
Asked by: psparks
Yes this will work with that TV.
Date published: 2013-06-28
  • 2016-02-06T08:32CST
  • loc_en_US, sid_185-632, PRD, sort_recentQuestionsFirst
