ProMounts UA-PRO230 30"-55" Articulating TV Wall Mount
Brand:|Model: UA-PRO230|Part # 185-600
The UA-PRO230's heavy duty single-arm double pivot is designed for maximum extension, folding flush to the wall and viewing from multiple positions.
List Price$429.95
You Save58%
$181.47
Buy 4+$172.39
Part # 185-600
  • VESA from 200 x 200 to 800 x 400
  • Extends up to 24" from the wall
  • Removable arm inserts for complete and easy cable management
  • Attractive end caps conceal tensioning hardware
  • All screen and mounting hardware included
A modern design for an extremely flexible, articulating universal wall mount for large flat panel displays. The UA-PRO230's heavy duty single-arm double pivot is designed for maximum extension, folding flush to the wall and viewing from multiple positions. Extends up to 26" from the wall and rotates from landscape to portrait. Features complete cable management, attractive end caps to conceal tensioning bolts and all screen and mounting hardware included The wall plate attaches to two studs up to 20" apart and concrete or aggregate walls. The UA-PRO230 universal wall mount comes complete with the all new TV adaptor in the box to fit screens from 32" to 55".
Specifications: • Max load: 150 lbs. • VESA patterns: 200 x 200 to 800 x 400 • Manufacturer's Limited Lifetime Warranty
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59"
  • BrandProMounts
  • ModelUA-PRO230
  • Part Number185-600
  • UPC856476001535
  • Product CategoryTV Mounts & Brackets
    (3 Reviews)
  • Weight31 lbs.
View similar products to the ProMounts UA-PRO230 30"-55" Articulating TV Wall Mount
in the TV Mounts & Brackets product category.
ProMounts UA-PRO230 30"-55" Articulating TV Wall Mount is rated 3.6667 out of 5 by 3.
Rated 3 out of 5 by from Good value for an articulating wall mountVery rugged [strong] design with little chance of structural failure. Bearing-surfaces of the articulating joints are rugged but NOT DESIGNED FOR EASY REPOSITIONING OF SCREEN. Plastic fascia are poorly designed and likely to fail in installations that will see much repositioning. I did manage to route 1 power, 1 HDMI, 1 stereo RCA and 1 component video cable with the given "cable management track" but it required many trade-offs to make it work. A low price makes these trade-offs acceptable.
Date published: 2012-06-22
Rated 3 out of 5 by from Fake DescriptionDoes NOT "rotates from landscape to portrait" unlike many other mounts. It can not rotate at all. It ONLY tilts when you loosen two screws which you then tighten afterwards to secure the set from falling over. "Cable management" within the arm is too small. You can barely fit a single cable within the small space not used by the metal support mechanism. Hardware itself is very solidly built but there are better mounts available for certain users. This is great if you need to swivel a HDTV around often with minimal effort since it can be pulled from the wall to allow you to point a TV to the other part of the room (without the end of the HDTV hitting the wall) and not just directly across the room from from where it's mounted like flat mounted designs thus it's about the same as a good table mount only attached to the wall instead of a table. Can probably hand 60" LED but not Plasma due to weight issues.
Date published: 2011-08-10
Rated 5 out of 5 by from Heavy DutyThese mounts are made to last! It is almost as heavy as the led tv that it holds up. Easy to mount and comes with everything you need.
Date published: 2011-07-07
  • 2016-02-05T06:41CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_185-600, PRD, sort_mostRecent
like the extension & ldscp to portrait didn't notice any tilt adjusment?
Asked by: TP guy
There is tilt adjustment capability with this unit, facilitated by a nut/bolt that is loosened to adjust, and tightened when the proper viewing angle is attained.
Answered by: RussR
Date published: 2011-05-16
  • 2016-02-05T07:15CST
  • loc_en_US, sid_185-600, PRD, sort_recentQuestionsFirst
