ProMounts Fino FT44 Tilting TV Wall Mount 10"-40"
ProMounts Fino FT44 Tilting TV Wall Mount 24"-40"
Brand:| Model: FT44
The ProMounts Fino FT44 tilting TV mount is ideal for mounting a medium-sized television above the viewer's direct line of sight.
  • Tilting action ensures the best viewing angle
  • Securely holds TV 1.45" from wall
  • 80 lbs. maximum load
  • Supports VESA patterns from 100 to 400
185-6558
Weight: 4.85 lbs.
IN STOCK
List Price$79.00
You Save64%
$28.30
Part # 185-6558
ProMounts' Fino FT44 mount features an adjustable tilt to give just the right viewing angle. This is tremendously helpful when a TV must be mounted above the viewer's field of vision. The mount's high quality aluminum construction and included mounting hardware make installation easy and worry-free, while the Secure Locking System prevents theft or accidental removal. Manufacturer's limited lifetime warranty.
To find out which Fino mount will work best for your flat screen TV, check out the Fino Product Finder!
Specifications: • Supports 24"–63" flat panel displays • Weight capacity: Up to 80 lbs. • Supports all VESA patterns from 200x200 to 400x400 • Distance from wall: 1.45".
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV CapacitySmall (< 24")
  • BrandProMounts
  • ModelFT44
  • Part Number185-6558
  • UPC852314002016
  • Product CategoryTV Mounts & Brackets
    (1 Reviews)
  • Weight4.85 lbs.
View similar products to the ProMounts Fino FT44 Tilting TV Wall Mount 24"-40"
in the TV Mounts & Brackets product category.
ProMounts Fino FT44 Tilting TV Wall Mount 24"-40" is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from Good for a lightweight 32+ inch set, but . . .First the good news: it works well for what it is designed to do. The part that mounts on the wall is completely open so if you are running your cabling through the wall you have full access to the area between the studs to fit a connection box or cable feed-through. It's easy to assemble. The wall mount is reversible, so there is no upside-down. Bear in mind that it doesn't tilt up, only down. But so what, right?Now for the buts . . .If your set is less than 18" high, don't go with this mount. The brackets on the back of the set are 17" long - they have to be in order to fit a 400x400 VESA pattern. If your set's not tall enough, the brackets will show.If your set weighs more than 50 lbs, don't go with this mount. It's a lighter, thinner grade of metal than you would want for a heavier set.Because of the design of the tilt mechanism, it's not very low-profile. If that's an issue, I strongly recommend the Dayton "Shadow Mount" line.Lastly, it doesn't come with the usual complement of mounting hardware. If you don't have some extra machine screws on hand, you might want to make a different purchasing choice. It comes with the bare minimum, much less than most other medium to large size mounts I've seen and used.
Date published: 2013-03-07
What are VESA patterns 200-400?
I have a small 26' Sharp flat panel TV. Looking to mount it on the wall for my granddaughters to watch. Bolt mounting pattern on the back is 4" X 4". Will the tilting bracket #185-6558 work or should I stick with the fixed bracket #185-6550? Thanks for your help
Asked by: sparky58
This mount will handle a VESA pattern from 100x100 up to 400x400. These measurements are in millimeters, so 4"x4" is 100x100. This will work with that TV.
Customer projects that include: ProMounts Fino FT44 Tilting TV Wall Mount 24"-40"
