Clearance Center  |  Speaker Buyouts  |  Special Offers  |  New Products  |  Cable Finder
0 items - $0.00
Sign In  |   Create Account   |  Contact Us
The #1 Source for Audio, Video and Speaker Building Components!
New Year, Great Gear Knock Down Cabinets
Design Goals  |  Driver Selection  |  Enclosure Design  |  Enclosure Assembly  |  Crossover Design  |  Conclusion  |  Parts List  |  About The Designer
  Design Goals
The TriTrix was conceived with multiple enclosure possibilities in mind, enabling it to perform in diverse home theater or music applications. For maximum versatility, this high-value design can be built as a sealed, vented, or transmission line variant-the transmission line version will be the focus of this article. The system's crossover is optimized to provide good horizontal off-axis response when the speaker is used as a center channel, as well as in a vertical alignment for mains or surrounds. The TriTrix utilizes Dayton drivers exclusively, and unlike many MTM designs boasts a very easy eight ohm load in an MTM format.
  Driver Selection
The opportunity for an eight ohm MTM using Dayton Classic drivers was made possible when the DA130BS-4 was released. In my opinion, this four ohm version of the well respected 5-1/4" Dayton Classic-like its eight ohm sibling-has the best midrange of the Dayton Classic lineup. In addition, the DA130BS-4 boasts a sensitivity 3 dB higher than the eight ohm version. Using two of these drivers in a series results in a system with sensitivity that rivals many four ohm designs, yet provides an easy load for impedance-challenged amplifiers.
The DC28FS represents the latest version of this popular tweeter, and is arguably the best sounding version to date. It demonstrates a bit of a "BBC" dip around 4 kHz and exhibits a smoother top end than its predecessors. The woofer and tweeter are both shielded, and their acoustical abilities complement each other very well.
Dayton DC130BS-4 5-1/4"
Classic Shielded Woofer 4 OHM
Dayton DC28FS-8 1-1/8"
Shielded Silk Dome Tweeter
Dayton DESL-18G Dual-Ended
Spring-Loaded Gold Terminal Pair
  Enclosure Design
I've always found transmission lines intriguing, not only because of their attributes, but also because for so long their design was cloaked in mystery and conjecture, rules of thumb, and sometimes outright bunk. The recent works of Martin King and Augspurger, among others, have removed the veil on proper design-or at least made it somewhat more transparent.
Although their design process can be tricky, transmission lines provide an alternative solution to some basic acoustical challenges. Half of a driver's acoustic energy radiates from the back of the cone. In a sealed design, an attempt is made to dissipate this unwanted energy by absorbing it in stuffing, but in many cases a significant amount of energy reenters the cone- delayed in time, and revealed as response peaks due to internal standing waves. All of these effects cause distortion of the original signal.
A transmission line functions by using this wasted and unwanted acoustic energy in a positive manner. By encouraging standing waves of a single low frequency, and providing an opening (or terminus) out of which these standing waves can escape, the bass response of the driver can be extended. At the same time, the transmission line reduces the energy that reenters the cone and causes distortion. I chose the classic tapered transmission line for the TriTrix design for its characteristic nearly linear impedance, uncolored sound, good bass extension, and simplicity of construction.
One objective was to keep the enclosure volume as small and compact as possible. I used Martin King's "Classic Transmission Line Enclosure Alignment Tables" to design the enclosure, and verified it using his MathCad computer models.
A significant advantage of all the TriTrix designs is their relatively small enclosure volume requirement, no matter which version. For the sealed alternative, the external dimensions are a diminutive 20" x 6-1/4" x 8- 1/4" deep, and the max SPL models at in excess of 104 dB. Likewise, the TriTrix in a vented enclosure also lends itself to smaller volume of 19 liters, with an f3 in the low to mid fifties and an f10 right at 40 Hz.
Overall Dimensions
  Enclosure Assembly
Many thanks to my good friend Wayne Wendel for constructing the gorgeous piano black finish enclosures. I am told the enclosures are simple to build and a pair can easily be made from a single sheet of 3/4" MDF. To further dampen side panel resonance, two dowel type braces were added behind the drivers. The enclosure width is 7-1/2" with a 3/8" round-over on all sides. Height was arbitrarily limited to 36" in keeping with the compact nature of the design, but could be easily modified to accommodate a range of optimum listening heights. The cabinet's depth is 14-1/4". Acoustic foam was applied to the enclosure above and behind the drivers. The crossover was attached on the angle of the fold directly below the terminus.
I used polyfill to stuff the lines, but you can use fiberglass, Acousta StufT, or whatever strikes your fancy. I found that a light to medium fill behind the drivers and a medium to heavy fill from below the drivers to the terminus gave the best response for my preference in my own listening environment. Start out with moderate amounts of filling material per enclosure and stuff to taste.
  Crossover Design
Like many of my designs, this crossover is an exercise in simplicity. It almost turned out to be a four-element design, which actually modeled and measured better, but listening tests revealed sound quality inferior to the five-element design. Particular attention was paid to the vertical and horizontal off-axis response so that the design would work well when the drivers were oriented either vertically or horizontally.
You will notice the on-axis response is somewhat a departure from my normal designs in that it exhibits a rather broad dip between roughly 2 kHz and 6 kHz. This is due to the response of the Dayton Classic tweeter, and compounded by the narrow 6-1/2" baffle width. While this appears somewhat sub-optimal, in practice it sounds remarkably flat. Considering the crossover topology, I suspect the dip fills in off axis. The second order electrical filter of the woofer emulates a third order BW acoustical transfer function at 1200 Hz. The tweeter resembles, at least for a portion of the transition band, a fourth order LR at 1450 Hz. The impedance is quite high with a minimum of about seven ohms, and an average around eight ohms. Phase tracking is fairly good through the crossover region.
Crossover Schematic
Frequency Response Chart
Impedance Chart
  Conclusion
When I finished the TriTrix, I was surprised how good $160 worth of drivers and crossover parts could sound. I'd recommend them for home theater use or for music reproduction on a budget. The speakers' bass output is sufficient for most users to consider them "full range" for music applications. At a modeled max SPL of 104 dB, they can play quite loudly without obvious distortion setting in. They are just a bit forward when the listener is on-axis, due to the diffraction bump at around 2 kHz. This helps bring out the dialog for home theater work, but for music I prefer to listen to them slightly off-axis, which minimizes the effect.
  Parts List
Part #
Description
Qty
300-700 TriTrix DIY speaker building kit (Includes everything you need, except cabinets.)
300-701 TriTrix MTM TL Knock Down CNC Cabinet Pair
Add all available items for this project to your cart with one click of the mouse!
If you wish to add or remove products from this project parts list
you can do so anytime in your shopping cart before completing your order.
  About The Designer
Curt Campbell has been a music enthusiast all of his life, including live performance as a trained musician. His fascination with electronics and speaker building started early with building up some oddball project or other, usually with parts pilfered from other equipment. Curt's additional hobbies include woodworking, photography, and-along with keeping the family's vehicles running-rebuilding old sports cars. He enjoys his career in commercial aviation, where he supports and diagnoses avionics systems in corporate aircraft. His current speaker building passion is crossover design, and numerous projects on the PE Project Showcase and his own website feature his crossover work.
DISCLAIMER - Parts Express posts the "Project Showcase" as a community service. Projects displayed have not been tested or evaluated by our staff. We make no warranties whatsoever in regard to the projects' fitness for a particular purpose. Claims of performance or fitness are those of the contributor and not of Parts Express. Project re-production for commercial resale may be a violation of United States patent or trademark laws.
 • Authorized Distributor
 • Fast Shipping
 • No Hassle Returns
 • Highly Acclaimed Service
 • Testimonials
 • Build Your Own Speaker
 • Woofer Selection Guide
 • Speaker Selection Wizard
 • Crossover Building Guide
 • Pro Audio Selection Guide
 • Replacing Your Speaker
 • Car Audio Speaker Guide
 • Home Theater Subwoofers
Other Resources
 • Wizards, How-To's, Terms
 • Technical Help FAQs
 • Customer Service FAQs
View All Speaker Projects
About Us
Contact Us
Link To Us
Sell To Us
Tell Us How We're Doing
Retail Store
Security/Privacy Policy
Terms & Conditions
Website Terms of Use
Live Chat
Customer FAQs
Technical Help
En Español
Forms
Site Help
Track Shipments
View Your Invoice
Return a Product
Popular Searches
Product Recall
Video Gallery
Special Offers
Wholesale
Ebay - Scratch & Dent
Education Sales
Affiliate Program
Get Social on Facebook
Get Social on Twitter
Get Social on YouTube
Get Social via RSS
BizRate Customer Certified - Parts Express Reviews at Bizrate Better Business Bureau Internet Retailer Top 500
45-Day No Hassle Guarantee | Free Same Day Shipping Available
   Tech Talk
Get Deals Be the first to hear about new
and exciting products, special
pricing and incredible deals!
See This Week's "GET DEALS" Email arrow
Get Sales Flyer
View: Our Sales Flyer
Download: Our Sales Flyer (PDF)
Get Catalog
Order: The 2012 Catalog
View: Catalog  iPad: Catalog
Popular Products:  HDMI Cables |  TV Mounts |  In-Wall Speakers |  Car Speakers |  Replacement Speakers
Parts Express • 725 Pleasant Valley Dr. • Springboro, Ohio 45066 • USA • 800-338-0531      © 1996-2012 Parts Express, All Rights Reserved
S1
