Home Subwoofer Project: Red Wing Crock Subwoofer
Project Category
Speaker Projects
Tactile Transducer Projects
Home Subwoofer Projects
Home Audio Projects
Amplifier Projects
Car Audio Projects
Other Projects
  Add Your Project
Create projects with your own descriptions, photos, design goals, material selection, schematics, and share with other audio enthusiasts.
Shop Parts Express
Ready-to-Assemble Speaker Kits
Speaker Building Components
Find the Right Woofer
Red Wing Crock Sub
I wanted to build a sub to complete my home theater project and I had a limited budget and was new to subs. I have done a few car subs before but this was my first attempt at something at a home powered subwoofer. I was looking to use a 12" and I wanted it to be about 100W. I looked into making a stealth box for behind the couch or a standard cube. After discussing with the family, they recommended using a old family crock we have since it was solid and right now just taking up space. So after a few quick measurements I decided that would be the way to do it!
Red Wing Crock Sub
Designer: Jinonyx
Project Time1-8 hours
Project Complexitynovice
Project Cost$100-$500
Driver Selection
Dayton Audio SD315A-88 12" DVC Subwoofer- SD315A-88 I found this one and it seemed to fit all of my requirements and worked well in a sealed box with 2.5cuft. I wanted a 12" because it fit the opening of the crock and makes good amount of base with just a single driver. It is also has a dual voice coil providing a 4ohm load which worked well with the Dayton Audio SA100.
Enclosure Design
It is built into a red wing crock that we had sitting around. I cut a 21" circle lid out of 3/4" mdf and drilled a 12" hole in the middle to fit the woofer. The under side has two rings that are 17" od and 12"id to cut out of 1/2" plywood that are glued to the mdf lid that self centers the lid to the crock. Since the crock isn't perfectly round I used 1/4" foam gasket around inner lip of the crock and wedged the lid into it to make a tight seal. I placed a second 21" mdf disc over the first to make a cover to protect the face of the woofer. I still need to stain and varnish the wood to get it to match the rest of the speakers.
Dayton Audio SA100 100W Subwoofer Plate Amplifier- SA100 I chose this because it supplied enough power as well as being within my budget with the 60$ woofer. I was going to make a sealed box and mount the amp onto it but with the crock I don't have anywhere to mount it so I have it sitting next to the subwoofer.
Conclusion
Its a fun subwoofer that is a easy beginner project with decent base. I think a larger enclosure or ports might be necessary if I were to redo this build. It was made out of scrap wood I had from the 5 channel speakers I made for surround sound so it was a very cheap project costing only 150$ for the amp and sub.
Project Parts List
Dayton Audio SA100 100W Subwoofer Amplifier
Start a discussion about the Red Wing Crock Sub project.
Next > The Bottomless subwoofer.
top
