Home Subwoofer Project: Large Sound, Budget Pro/ Home Subwoofer
Project Category
Speaker Projects
Tactile Transducer Projects
Home Subwoofer Projects
Home Audio Projects
Amplifier Projects
Car Audio Projects
Other Projects
  Add Your Project
Create projects with your own descriptions, photos, design goals, material selection, schematics, and share with other audio enthusiasts.
Shop Parts Express
Ready-to-Assemble Speaker Kits
Speaker Building Components
Find the Right Woofer
large sound, budget pro/home subwoofer
I wanted a permanent solution for our theatre here at work which is a 50'/80' room with a stage at the long end and seats throughout. I have a set of Peavey PG1 15"/1.4" two way cabs flown up high and have previously been using my Dayton 10"8-8 dvc subs as a fill in (project to come), but decided to try these Dayton 15" 4ohm classic subs. They have exceeded my expectations by a great deal! and my box, which is about 4.5cf with 2- 1"/9"/17" ports shakes the building with no regard. I would highly recommend these subs for home and theatre use.
Designer: Theatergrandthree
Project Time1-8 hours
Project Complexitynovice
Project Cost$100-$500
Driver Selection
dayton 15" 4 ohm classic subwoofer
Enclosure Design
I used Winisd to come up with a 4.5 cf ported enclosure with two 1"/9"/17" ports out the bottom for an f3 of around 30hz, it has proved to have a small peak at around 37 hz but otherwise smooth from 30-120 hz, and acceptable by a large margin 10+ hz either way. The enclosures are large at 20'wide by 24' tall and 26" deep. I put casters and large plywood handles on these for pro and touring use, but an edge banded stained look, or painted style would be very nice for home use.
4ohm, needs active x-over at 120-60hz, or a 5mh inductor for a 135 hz 6db rolloff with slightly reduced power consumption.
Enclosure Assembly
I used birch 3/4"staingrade ply for the top, bottom and sides. i used one layer of mdf for the back (3/4") and two glued layers of 3/4" mdf for the front baffle. The port is based off the bottom with a single divider 16 1/4" long of 1/2" material with 1/2" matching pieces tight on either edge. A layer of 16 1/4" deep 3/4" ply goes on top of that to make the rest of the port. The rest of the box bracing is your opinion, but I did two 4" /3/4" wide vertical supports on the rear panel and four 4"/3/4" cross braces egually spaced on either side of the enclosure. I used 3/4" round router lines on the face and 1/4" rounds on the rest of the enclosure. It has 3" casters and 3/4" penn-elcom rubber feets. each box has a neutrix 2pole speaker socket and 14 gauge wiring internally with damping material.
These things rock the house and don't eat too much power to do it. they play plenty low and still hit the upper bass and kick drum.. for $126 a driver I'm so happy
About The Designer
I am a scenic carpenter and theater sound designer by day and a speaker enthusiast/ novice builder by night. I love to work in a space where I built the systems that the space employs and loves.
Project Parts List
Dayton Audio DCS380-4 15" Classic Subwoofer 4 Ohm
Neutrik NL2MP Speakon 2 Pole Panel Mount
Peavey Large Rubber Feet Set of 4
13 AWG 2C Speaker Cable 1 ft.
Start a discussion about the large sound, budget pro/home subwoofer project.
Next > Red Wing Crock Sub
