Home Audio Project: 15" 12" Tower System Using Surplus Wild Woofers
Project Category
Speaker Projects
Tactile Transducer Projects
Home Subwoofer Projects
Home Audio Projects
Amplifier Projects
Car Audio Projects
Other Projects
  Add Your Project
Create projects with your own descriptions, photos, design goals, material selection, schematics, and share with other audio enthusiasts.
Shop Parts Express
Ready-to-Assemble Speaker Kits
Speaker Building Components
Find the Right Woofer
15" 12" Tower System using surplus Wild Woofers
This project was made as a fun system a few years ago for my son. Each system uses both a previously used and rebuilt 15" and 12" CTS Wild Woofer, along with 4 each midrange drivers and tweeters that I purchased over the years.
Designer: jim22747
Project Time20+ hours
Project Complexityprofessional
Project Cost$100-$500
All the Woofers were removed from custom systems that I had built for others many years ago when I lived in the San Francisco Bay Area. The foam surrounds on the woofers had turned to goo after a few years and the speakers needed to be replaced. I didn't have the heart to throw these out, so I put them back in the boxes and into storage. One day a few years later, I received a catalog from one of my suppliers that advertised replacement surrounds and I purchased several sets of 12" and 15" surrounds at very low cost. I believe they were around $2-$3 each. I used these surrounds to rebuild these and other woofers. These systems use the 15" Wild Woofer as a Sub-Woofer in a separate chamber at the bottom of the enclosure with a crossover frequency of 125 Hz. This required a 10 mH choke that I hand-wound on Ferrite Rods salvaged from a couple of AM radio antennas! I used an LCR meter from my shop to accurately wind them. The enclosures are 48" high X 18" wide X 16" deep. As with all my designs, the midranges are all in separate chambers. Midranges and tweeters are wired in series-parallel sets of 4 to keep the impedance at 8 ohms and provide the proper power handling capacity. Enclosures are of 3/4" Oak-veneer plywood with lots of 1-1/2 x 1-1/2" fir stiffeners inside to reduce cabinet resonance. Cross overs are custom made and these systems have mid and high range level controls, with gaskets everywhere.
About The Designer
I have been building speaker systems since I was 15. My back ground is Communications Electronic Tech in the U.S. Navy in the mid 1960's, CNC Tech , Maintenance Technical Supervisor and Maintenance Manager for Fortune 500 companies , and Process Development Engineer using Autodesk Inventor for the last 10 years before retiring.
Start a discussion about the 15" 12" Tower System using surplus Wild Woofers project.
Next > 4-Way System for rear channels in Quad Surround System
