Home Audio Project: Jukebox Diablo
Project Category
Speaker Projects
Tactile Transducer Projects
Home Subwoofer Projects
Home Audio Projects
Amplifier Projects
Car Audio Projects
Other Projects
  Add Your Project
Create projects with your own descriptions, photos, design goals, material selection, schematics, and share with other audio enthusiasts.
Shop Parts Express
Ready-to-Assemble Speaker Kits
Speaker Building Components
Find the Right Woofer
Jukebox Diablo
I was the winner of a Pyle 'Mechless' car stereo (PLR34M) from a local church raffle recently. I have a decent stereo in my daily driver, so i took inspiration from the other "PE Project Gallery Designers" and built the "Jukebox Diablo".
Jukebox Diablo
Designer: Natchezclaiborne
Project Time8-20 hours
Project Complexityhobbyist
Project Cost$100-$500
The car stereo is basically an MP3 module with a AM/FM tuner and small amplifier all in one. The box is 1/2 inch plywood with a 1/2 inch thick extruded black plastic front. Dimensions are 20"L x 12"H x 10"D, The speakers are 'Boss Phantom Skull' 5.25 & 6.50. The tweeters are "Vifa" square frame 1" tweeters with a 3500hz capacitor and a 1 ohm 5 watt resistor crossover. The box is covered with Black Bronco vinyl Tolex, Peavey small rubber feet, Penn-Elcom cabinet corners and a 10 inch carry strap finish the outside. Red led volt meter and a blue skull switch accompany the front. The rear has two 1 inch ID X 4 inch long port tubes, along with a pair of Dayton gold binding posts for charging The 12 volt 12ah power supply battery inside the box below the mechless unit. The portable stereo weighs about 20 lbs. A full charge lasts about 6 hours on medium to high volume. No iPod needed because the tunes are all on a 16GB Secure Digital (SD) Card. The Jukebox Diablo has been tested at several outings, picnics and tailgate parties. Everyone who sees it and hears it always Exclaim, "Can you make one for me?!.."
About The Designer
Employed as an Information Tech assistant Director for a local government agency. Degree in computers and electronic repair from a Community College.
Project Parts List
Vifa BC25SC55-04 1" Square Frame Tweeter
BOSS SK653 PHANTOM SKULL 6-1/2" 3-Way Speaker Pair
BOSS SK553 PHANTOM SKULL 5-1/4" 3-Way Speaker Pair
Red LED 8.5~30 VDC Panel Meter with Auto Brightness
Strap Type Cabinet Handle 10"
Port Tube 1" ID x 4" L Flared
Peavey Small Rubber Feet Set of 4
Penn-Elcom C1539 Ribbed Plastic Stacking Cabinet Corner
Vintage Marshall Style Black Bronco Tolex Vinyl Speaker Cabi
Dayton Audio BPA-38G HD Binding Post Pair Gold
Power-Sonic PS-12120 Sealed Lead Acid Battery 12V 12Ah
Start a discussion about the Jukebox Diablo project.
Next > 4 channel 125 watt RMS Sound System.
