Pro Wire MP-8 In-Wall Media Panel and Labeling System
Brand:|Model: MP-8|Part # 261-280
This sleek attractive panel from Pro-Wire will allow you to install up to 8 Decora® style low voltage devices into a single panel and uses a unique three-step mounting process. A 9 mm labeling system is included that enables you to keep track of which termination goes to each room.
OUT OF STOCK
Due In: 12/13/2016
$92.62
Buy 4+$89.45
Part # 261-280
  • Sleek and attractive method of mounting low voltage devices
  • Alternative to structured wire enclosures
  • 9 mm labeling system included
  • Unique three-step mounting process
  • This is a blank panel and the inserts shown in the picture are not included
This sleek attractive panel from Pro-Wire will allow you to install up to 8 Decora® style low voltage devices without compromising appearance. Additionally, the MP-8 can be used as an alternative to a structured wire enclosure for "home-run" type installations. Unique to the MP-8 is a three-step mounting process. First, cut the mounting hole in accordance with the included template. Next, install the mounting frame into the wall. Populate the panel with low voltage devices, and you're finished. A 9 mm labeling system is included that enables you to keep track of which termination goes to each room. Low voltage devices sold separately. White in color.
Specifications: • Overall dimensions: 12-3/4" H x 9-1/8" W x 2-1/2" D • Cutout: 11-3/4" H x 8-1/8" W • Mounting depth: 2-3/8".
  • BrandPro-Wire
  • ModelMP-8
  • Part Number261-280
  • UPC769381777900
  • Product CategoryLow Voltage Boxes & Mounting Brackets
    (1 Reviews)
  • Weight3.08 lbs.
View similar products to the Pro Wire MP-8 In-Wall Media Panel and Labeling System
in the Low Voltage Boxes & Mounting Brackets product category.
