Pro Co WP1004 (1) XLR Female Wallplate Single Gang
Brand:| Model: WP1004
Attention Installers! These pre-assembled wall plates are constructed of brushed 430 stainless steel alloy and utilize some of the highest quality connectors available. The male metal latching XLR connector is riveted for durability and all conductors are panel-isolated.
248-102
Weight: 0.25 lbs.
IN STOCK
List Price$17.99
You Save36%
$11.36
Buy 4-up$10.33
Part # 248-102
Attention Installers! These pre-assembled wall plates are constructed of brushed 430 stainless steel alloy and utilize some of the highest quality connectors available. The male metal latching XLR connector is riveted for durability and all conductors are panel-isolated. All plates conform to NEMA box standards and include mounting hardware.
  • BrandPro Co Sound
  • ModelWP1004
  • Part Number248-102
  • UPC703272028337
  • Product CategoryCommercial Wall Plates
    (3 Reviews)
  • Weight0.25 lbs.
View similar products to the Pro Co WP1004 (1) XLR Female Wallplate Single Gang
in the Commercial Wall Plates product category.
Pro Co WP1004 (1) XLR Female Wallplate Single Gang is rated 2.6667 out of 5 by 3.
Rated 3 out of 5 by from Don''t buyThis is the first bum part I've found with parts express.The push tab that releases the plug is easily pulled out by someone not knowledgeable with XLR wall plates, wrecking the plug. They need to discontinue this item.For those that know what they are doing, they work fine.When I order again, it will not be this model, normally Pro Co products have worked well for me.
Date published: 2012-12-22
Rated 4 out of 5 by from wall micThis product is as described and works as advertesed.
Date published: 2011-02-17
Rated 1 out of 5 by from Amp connector NOT NeutrikAccording to the catalog this item comes with a Neutrik "D" series connector. That is totally false, this item comes with a inferior Amp connector.
Does this plate or the black one like it requie sodering to make connections to wires on the back side or is there a connection already there
I am looking at this to install to connect a microplex xlr lighting cable to that runs through the inside structure of a church building. Thanks
Asked by: dbjelland
To provide solid connection with XLR to signal wires, they always require soldering. As far I know XLR connectors only comes with terminals for soldering. This is the case with all professional multimedia application to prevent oxidation and contact deterioration. This is balanced three wire connector for a both audio and special lighting control.For lighting control the bottom #3 is the signal when the lock is on the top, left #2 is the positive voltage and the right #1 ground.
Answered by: PasiPT
Date published: 2012-03-03
Customer projects that include: Pro Co WP1004 (1) XLR Female Wallplate Single Gang
