PreSonus StudioLive 16.4.2 16-Ch Digital Mixer 16 x 4 x 2
Brand:|Model: StudioLive 16.4.2|Part # 246-2520
You'll never go back to an old-school analog mixer once you've used StudioLive™. With its incredible signal-processing power on all 16 channels, easy store and recall of every setting, and the ability to record it all with just two mouse clicks, you'll get spoiled fast!
Comparable Items In Stock:
Part # 246-2520
  • 16 mic/line inputs with high-headroom Class A XMAX™ mic preamplifiers
  • 4 subgroups
  • Stereo/mono main out
  • 6 auxiliary mixes
  • 32-in/18-out FireWire digital recording ­interface (24-bit/44.1 kHz and 48 kHz)
  • Studio One Artist Digital Audio Workstation software for Mac™ and PC
  • Capture™ 1.1 recording software for Mac™ and PC
You'll never go back to an old-school analog mixer once you've used StudioLive™. With its incredible signal-processing power on every channel, easy store and recall of every setting, and the ability to record it all with just two mouse clicks, you'll get spoiled fast! Easier to use, better sounding, and flawlessly integrated with state-of-the-art software, it delivers the most creative environment possible for both live performance and studio music production.
But StudioLive is not simply a mixer, it's a rapidly growing family of state-of-the-art, integrated hardware-software mixing and recording systems that deliver the features you need for live sound, live recording, and studio recording.
The StudioLive 16.4.2 is a great choice for those who want to mix smaller shows and worship services, and it's a great choice for small club systems, portable churches, small bands, corporate applications, educational institutions, and anywhere you want a rack-mount mixer. It's the perfect hardware core for a project studio. Or daisy-chain two StudioLive 16.4.2s to form a 32x8x2 performance and recording console for mid-sized shows and events.
Here, in one device, are high-headroom XMAX™ microphone preamplifiers, a built-in FireWire recording and playback interface, more than 90 signal processors, a big library of DSP effects, 6 aux buses, 4 subgroups, extensive LED metering, mixer save and recall, channel-strip save/recall/copy/paste, talkback, and more. Yet despite its many controls and features, it’s compact, rack-mountable, and easy to transport.
Build live mixes that glisten with clarity and detail—then record and enhance the performance with the power of StudioLive 16.4.2. Get creative in the studio. Build mixes, loops, sound effects, and more, then bring them out to your show and mix them with the live performance. Process channels using your favorite plug-ins and completely automate your entire performance. StudioLive 16.4.2 revolutionizes music production, opening endless creative possibilities. See it. Touch it. Change it: the ease of analog meets the power of digital.
Sit down at a StudioLive 16.4.2, and you see real hardware Mute and Solo buttons, trim controls, and clearly labeled, individual knobs for the semi-parametric EQ and dynamics processing. The master section—complete with Talkback, Monitor, Cue, and a choice of headphone sources—looks just like the master section on an analog board but with far more power and flexibility. Aux sends have their own controls. Every channel has a big, bright meter display.
Microphone Preamp 1-16 (XLR Balanced)
  • Type: XLR Female, balanced
  • Frequency response to direct output: 20 Hz to 40 kHz ±0.5 dBu
  • Frequency response to main output: 20 Hz to 20 kHz ±0.5dBu
  • Input impedance (Balanced): 1K ohm
  • THD to direct output: <0.005%, +4 dBu, 20-20 kHz, unity gain, unwtd
  • THD to main output: <0.005%, +4 dBu, 20-20 kHz, unity gain, unwtd
  • EIN to direct output: +125 dB unwtd,, +130 dB A-wtd
  • S/N ratio to direct output: -97 dB
  • S/N ratio to main output: -94 dB
  • Common mode rejection ratio: +65 dB
  • Gain control range: -16 dB to +67 dB (+/-1 dB)
  • Maximum input level (unity gain): +16 dBu
  • Phantom power: +48 VDC
    Line Inputs
  • Type: 1/4" TRS Female, balanced mono
  • Frequency response to direct outputs: 10-40 kHz, 0/-0.5 dBu
  • Frequency response to main outputs: 20-20 kHz, +/-0.5 dBu
  • Input impedance: 10 k
  • THD to direct output: <0.0007%, +4 dBu, 20-20 kHz, unity gain, unwtd
  • S/N Ratio to direct output: -105 dB
  • S/N Ratio to main output: -94 dB
  • Gain control range: -20 dB to +20 dB (+/- 1 dB)
  • Maximum input level (unity gain): +22 dBu
    Tape Inputs
  • Type: 1/4" TRS female, balanced mono
  • Maximum input level: +10 dBu
    Auxiliary Inputs
  • Type: 1/4" TRS Female, balanced (2 stereo pairs)
  • Maximum input level: +22 dBu
    Main Outputs
  • Type: Male, balanced (stereo pair); 1/4" TRS Female, balanced (stereo pair); XLR Male, balanced (mono)
  • Rated output level: +24 dBu
  • Output impedance: 10 k ohms
    Aux Outputs
  • Type: 1/4" TRS Female, balanced (mono)
  • Rated output level: +18 dBu
  • Output impedance: 51k ohms
    Subgroup Outputs
  • Type: 1/4" TRS female, balanced (mono)
  • Output impedance: 51 k ohms
    Tape Outputs
  • Type: RCA Female, unbalanced (stereo pair)
  • Output impedance: 100 k ohms
    Control Room Outputs
  • Type: 1/4" TRS female, balanced (stereo pair)
    System Cross Talk
  • Input to output: -90 dBu
  • Adjacent channels: -87 dBu
    Noise Gate/Expander
  • Threshold range: -84 dB to 0 dB
  • Attack time: 0.5 ms
  • Release time: 0.05s to 2s
  • Expander attenuation range: 2:1
    Compressor
  • Threshold range: -56 dB to 0 dB
  • Ratio: 1:1 to 14:1
  • Attack time: 0.2 ms to 150 ms
  • Release time: 40 ms to 1000 ms
  • Auto attack and release: Attack = 10 ms, Release = 150 ms
  • Curve types: Hard and soft knee
    EQ
  • Type: 2nd order shelving filter (Q = 0.55)
  • Low (Lowpass or Bandpass): 36 to 465 Hz, ± 15 dB
  • Low mid: 90 Hz to 1.2 kHz, ±15 dB
  • High mid: 380 Hz to 5 kHz, ±15 dB
  • High (Highpass or Bandpass): 1.4 kHz to 18 kHz, ±15 dB
    Digital Audio
  • ADC dynamic range (A-wtd, 48 kHz): 118 dB
  • DAC dynamic range (A-wtd, 48 kHz): 118 dB
  • FireWire: S400, 400Mb/s
  • Internal processing: 32-bit, floating point
  • Sampling rate: 44.1, 48 kHz
  • A/D/A bit depth: 24
  • Reference level for 0 dBFS: -18 dBu
    Power/Environmental
  • Connector: IEC
  • Input-Voltage range: 100 to 240 V~, 50-60 Hz
  • Power requirements (continuous): 100 watts
  • Temperature range: 0 - 40 degrees celsius
    Physical
  • Dimensions: 22.35" L x 17.22" W chasis only, 19" W w/rack ears x 6.9" max H (568.06 x 437.40 x 482.60 x 175.26 mm)
  • *Please see complete mechanical drawings when building a custom rack, desk or case.
  • Weight: 23 lbs.
  • PRODUCT SPECIFICATIONS
    • Mixer TypeDigital
    • Special FeaturesDigital Effects,USB Connectivity
    • XLR Mic Inputs16 to 23
    • BrandPreSonus
    • ModelStudioLive 16.4.2
    • Part Number246-2520
    • UPC673454000607
    • Product CategoryMixers - Live Sound & Recording
      (2 Reviews)
    • Weight44.2 lbs.
    View similar products to the PreSonus StudioLive 16.4.2 16-Ch Digital Mixer 16 x 4 x 2
    in the Mixers - Live Sound & Recording product category.
    Videos
