PreSonus StudioLive 16.0.2 16-Ch Digital Mixer 16 x 2
Brand:|Model: StudioLive 16.0.2|Part # 246-2518
Meet the StudioLive 16.0.2! The compact, 16-channel StudioLive 16.0.2 offers 8 mono input channels and 4 stereo channels, 60 mm faders (the 16.4.2 and 24.4.2 have 100 mm faders), and 4 aux buses.
  • 8 mono mic/line channel inputs
  • 4 stereo line channel inputs
  • 4 Auxiliary buses (pre/post-fader send)
  • 2 Internal FX buses
  • 2 stereo 32-bit digital effects processors with customizable reverb and delay presets
  • 16-in/16-out FireWire recording interface (24-bit/44.1 kHz and 48 kHz)
  • MIDI Control Mode
The new StudioLive 16.0.2 delivers the same basic technology at a stunningly low price— and adds MIDI control! You might not need oodles of mixer inputs and subgroup buses if you’re playing in a garage band or operating a modest home studio, a small school theater, or a coffeehouse. Ditto if you’re renting a mixer for a hotel presentation or panel discussion. And you shouldn’t have to pay for features you don’t need. But of course, everyone wants a mixer with great audio quality, and it’s a tremendous advantage to have quality onboard dynamics processing and EQ. Meet the StudioLive 16.0.2! The compact, 16-channel StudioLive 16.0.2 offers 8 mono input channels and 4 stereo channels, 60 mm faders (the 16.4.2 and 24.4.2 have 100 mm faders), and 4 aux buses.
But don’t let its size fool you; the 16.0.2 is jam-packed with features and processing power, employs the same workflow and easy-to-use mixing surface design as the bigger boards, and sounds every bit as good, with the same high-definition digital converters and 12 XMAX™ Class A solid-state mic preamps. The 16.0.2 integrates a 16x16 FireWire interface and comes with Capture, Studio One Artist, and Virtual StudioLive, and it works great with our free SL Remote iPad control app. Its Fat Channel is well stocked with compressors, limiters, expanders, phase reverse, high-pass filters, and 3-band semiparametric EQ, and two stereo, 32-bit floating-point effects processors deliver the same great delay and reverb effects you’ll find in the 16.4.2 and 24.4.2.
Moreover, a glance at the rear panel reveals that "Junior" offers something the two bigger boards don’t: MIDI In and Out. You can recall Scenes from a DAW using MIDI Program Changes, control the main output volume and effects level,
and even mute effects between songs— all thanks to the magic of MIDI control. Did we mention that you get all this for a stunningly low price? That is an understatement!
Our StudioLive™ 24.4.2 and 16.4.2 changed the game, offering amazing performance and ease of use for a great price. Now we’ve packed the same audio quality, performance, seamlessly integrated software (including remote control) into a smaller, even more affordable package. Small size. Bigger possibilities. In a "footprint" of less than 2 square feet (0.19 m2), the compact, 16-channel StudioLive 16.0.2 offers 8 mono input channels and 4 stereo channels and provides 12 XMAX™ Class A solid-state mic preamps. (Well, okay, it actually has 13 XMAX preamps; the Talkback input has one, too.)
The 16.0.2 integrates a 16x16 FireWire interface and comes with Capture™, Studio One Artist™ recording and production software, and Virtual StudioLive, bidirectional control software, and it works great with our free SL Remote iPad and iPhone control apps.
The 16.0.2's Fat Channel is well stocked with compressors, limiters, gates, phase reverse, high-pass filters, and 3-band semi-parametric EQ. Two stereo, 32-bit floating-point effects processors deliver delay and reverb effects.
Moreover, a glance at the rear panel reveals that "Junior" offers something the two bigger boards don't: MIDI In and Out. You can recall Scenes from a DAW using MIDI Program Changes, control the main output volume and effects level, and even mute effects between songs—all thanks to the magic of MIDI control.
Two factors work against getting that Perfect Mix with an analog mixer. First, the Perfect Mix can be hard to reproduce a week, day, or hour after you perfect it. And second, a good mix should be dynamic: levels, effects, and EQ should be tailored to each song or segment of the show, service, or presentation. StudioLive solves this problem by letting you save all of your digital settings for quick setup and recall.
Microphone preamp
  • Type: XLR Female, Balanced
  • Frequency response to direct output (at unity gain): 20 Hz-40 kHz, 0/-0.5 dBu
  • Frequency response to main output (at unity gain): 20 Hz - 20 kHz, ±0.5 dBu
  • Input impedance (Balanced): 1 k
  • THD to direct output (1 kHz at unity gain): <0.005%, +4 dBu, 20 Hz–20 kHz, unity gain, unwtd
  • THD to Main output (1 kHz at unity gain): 0.005%, +4 dBu, 20 Hz-20 kHz, unity gain, unwtd
  • EIN to direct output: +125 dB unwtd, +130 dB A-wtd
  • S/N ratio to direct output (Ref = +4 dB, 20 kHz BW, unity gain, A-wtd): -97 dB
  • S/N ratio to main output (Ref = +4 dB, 20 kHz BW, unity gain, A-wtd): -94 dB
  • Common mode rejection ratio (1 kHz at unity gain): +65 dB
  • Gain control range (± 1 dB): -16 dB to +67 dB
  • Maximum input level (unity gain): +16 dBu
  • Phantom power (± 2 VDC): +48 VDC
    Line inputs, balanced
  • Type 1/4" TRS female, balanced mono
  • Frequency response to direct outputs (at unity gain): 10 Hz - 40 kHz, 0/-0.5 dBu
  • Frequency response to main outputs (at unity gain): 20 Hz - 20 kHz, 0/-0.5 dBu
  • Input impedance: 10 k
  • THD to direct output (1 kHz at unity gain): <0.0007%, +4 dBu, 20 Hz - 20 kHz, unity gain, unwtd
  • THD to main output (1 kHz at unity gain): <0.005%, +4 dBu, 20 Hz-20 kHz, unity gain, unwtd
  • S/N ratio to direct output (Ref = +4 dBu, 20 kHz BW, unity gain, A-wtd): -105 dB
  • S/N ratio to main output (Ref = +4 dBu, 20 kHz BW, unity gain, A-wtd): -94 dB
  • Gain control range (± 1 dB): -20 dB to +20 dB
  • Maximum input level (unity gain): +22 dBu
    Line inputs, unbalanced
  • Type: RCA Female, unbalanced (stereo pair)
  • Maximum input level: +22 dBu
    Main outputs
  • Type: XLR Male, balanced (stereo pair); 1/4" TRS Female, balanced (stereo pair)
  • Rated output level: +24 dBu
  • Output impedance: 10 k
    Aux outputs
  • Type: 1/4" TRS Female, balanced (mono)
  • Rated output level: +18 dBu
  • Output impedance: 51 k
    Monitor outputs
  • Type: 1/4" TRS female, balanced (stereo pair)
    System cross talk
  • Input to output (Ref = +4 dBu, 20 Hz-20 kHz, unwtd): -90 dBu
  • Adjacent channels (Ref = +4 dBu, 20 Hz-20 kHz, unwtd): -87 dBu
    Noise gate (Expander)
  • Threshold range: -84 dB to 0 dB
  • Attack time: Adaptive (0.2 - 2.5 ms)
  • Release time: 70 ms
  • Expander attenuation range: 2:1
    Compressor
  • Threshold range: -56 dB to 0 dB
  • Ratio: 1:1 to 14:1
  • Response time (Attack/Release): 0.2 ms/1.0 s ("Tight") to 180 ms/1.0 s ("Smooth")
  • Auto attack and release: Auto attack = 10 ms, Release = 150 ms
  • Curve types: Hard and soft knee
    EQ
  • Type: 2nd - order shelving filter (Q = 0.55)
  • Low (Low-pass or Bandpass): 36 to 465 Hz, ± 15 dB
  • Mid: 26 Hz to 3.5 kHz, ±15 dB
  • High (High-pass or Bandpass): 1.4 kHz to 18 kHz, ±15 dB
    Digital audio
  • ADC dynamic range (A-wtd, 48 kHz): 118 dB
  • DAC dynamic range (A-wtd, 48 kHz): 118 dB
  • FireWire: S400, 400 Mb/s
  • Internal processing: 32-bit, floating point
  • Sampling rate: 44.1, 48 kHz
  • A/D/A bit depth: 24 bits
  • Reference level for 0 dBFS: -18 dBu
    Power
  • Connector: IEC
  • Input-voltage range: 90 to 240 VAC (factory-configured for country of destination)
  • Power requirements (continuous): 100 watts
    Physical
  • Dimensions: 15.56" L x 16" W x 5.5" max H (397 x 106 x 140 mm)
  • Weight: 20 lbs.
  • PRODUCT SPECIFICATIONS
    • Mixer TypeDigital
    • Special FeaturesDigital Effects,USB Connectivity
    • XLR Mic Inputs6 to 8
    • BrandPreSonus
    • ModelStudioLive 16.0.2
    • Part Number246-2518
    • UPC673454001253
    • Product CategoryMixers - Live Sound & Recording
      (1 Reviews)
    • Weight28.55 lbs.
    View similar products to the PreSonus StudioLive 16.0.2 16-Ch Digital Mixer 16 x 2
    in the Mixers - Live Sound & Recording product category.
