PreSonus Monitor Station Desktop Studio Control Station
Brand:|Model: Monitor Station|Part # 246-2558
Based on the award-winning Central Station, the Monitor Station provides talkback, speaker switching, input source switching and four ultra loud and clear headphone amplifiers delivering everything you need to control your recording environment.
Part # 246-2558
  • Main speaker volume adjustment
  • 3 stereo inputs (two balanced TRS, one RCA Aux/Phono)
  • Three sets of balanced TRS speaker outputs each with level adjustment
  • Talkback microphone with volume control to feed headphone and Cue output
  • XLR input for external dynamic talkback microphone
  • Accurate dual 8-segment LED for metering
  • 4 loud & clear headphone amplifiers w/separate volume control & independent input source selection
Frequently Bought Together
The Monitor Station is the ultimate desktop monitoring and communications system for your recording studio. Based on the award-winning Central Station, the Monitor Station provides talkback, speaker switching, input source switching and four ultra loud and clear headphone amplifiers delivering everything you need to control your recording environment. The Monitor Station allows you connect up to three input audio streams (TRS1, TRS2, Aux/Phono) allowing you to switch between and compare different inputs. One application is used to connect your computer recording system main outputs to the TRS 1 inputs and a CD player's outputs to the Aux inputs on the Monitor Station to compare your mix with a commercial CD with the touch of a button.
Speaker Switching
Three sets of speaker outputs are loaded on the Monitor Station allowing you to audition your mix on different speakers to take the guessing out of how your mixes will translate in the real world.
Main and Cue Routing
The Monitor Station allows each of the stereo inputs (TRS1, TRS2, aux) to be routed to one of two audio paths, "main" and "cue". The Monitor Station allows you to route two separate signals (Main and Cue) to each of the four headphone amplifiers.Send a mix with click track to TRS 2 input while sending the "main mix" to TRS 1. You can then enable the headphone amplifiers to listen to either cue or main mix. The main audio path always feeds what you will hear in the control room.
Customize Your Monitor Station
Three different functions on the Monitor Station can be set and saved during power up so that you can customize your recording system for the way you work. Input selection can be set in either "summing" mode (TRS1, TRS2, and Aux/Phone are summed together when engaged), or in "toggle" mode (TRS1, TRS2, and Aux/Phono can only be selected one at a time).
Speaker selection can either work in "all on" mode (speaker A, B and C can be engaged simultaneously), in "toggle" mode (speaker A, B, and C can only be selected one at a time), or in "subwoofer" mode (A and B are selectable while C can be selected with A or B). The Monitor Station's LED signal meters can also be set in three different modes for various signal levels (-10 dB, +4 dB and +10 dB).
Headphone Amplifiers that "go to 11"
PreSonus has built a reputation for delivering the best-sounding headphone amplifiers available. Each of the four headphone amplifiers loaded in the Monitor Station deliver 150 milliwatts and are able to power any headphone with as much loud and clear volume needed for everyone in the band, including the drummer.
  • BrandPreSonus
  • ModelMonitor Station
  • Part Number246-2558
  • UPC673454000713
  • Product CategoryMonitoring & Controllers
  • Weight6.75 lbs.
View similar products to the PreSonus Monitor Station Desktop Studio Control Station
in the Monitoring & Controllers product category.
