PreSonus FireStudio Project 10x10 Firewire Interface
Brand:|Model: FireStudio Project|Part # 246-2504
The FireStudio Project a complete 24-bit/96K professional recording system combining eight Class A XMAX microphone preamplifiers, 24-bit/96k sample rate conversion, and a zero-latency matrix router mixer.
Part # 246-2504
  • Improved analog to digital converters (114 dB dynamic range)
  • Improved syncronization with JetPLL™ (jitter elimination technology)
  • FireControl Mixer/Router send up to five separate zero-latency stereo mixes
  • Three-segment LED input metering on all analog channels
  • Internal IEC-based power supply
  • PreSonus Studio One Artist bundle w/Native Effect plug-ins & third-party instruments, loops, & apps
  • High-Speed FireWire (IEEE 1394) Audio Interface
Frequently Bought Together
The FireStudio Project is the next-generation of the award-winning FP10/FirePod with the following improvements:
  • Improved analog to digital converters (114dB dynamic range)
  • FireControl Mixer/Router to send up to five separate zero-latency stereo mixes to musicians during recording
  • PreSonus Studio One Artist bundle with Native Effects plug-ins and third-party instruments, loops, and applications
8 XMAX Class A Preamplifiers
The FireStudio Project includes eight custom-designed high-voltage, discrete, XMAX Class A microphone preamplifiers for all types of microphones. Many other companies offering recording interfaces add the cheapest possible microphone preamplifier as an afterthought to the interface. PreSonus knows that the preamplifier is a key component in the sonic quality of a recording. The job of a microphone preamplifier is to boost microphone level signals to line level so that the signal can be converted from analog to digital. This mic to line boost is generally a preamplification of over 400 times the voltage of the original mic level signal. This preamplification stage is one of the most important stages that the signal will go through before converted to digital, and is why a high performance preamplifier is important to achieving great results. A cheap "off the shelf op-amp" type mic preamp that is found in most interfaces translates into thin, noisy and harsh results.
All XMAX preamplifiers are built with the same three elements:
    High Voltage - The XMAX preamplifier runs on power rails of 30V. Most off the shelf op amp based designs run on power rails of 10V to 18V. Higher voltage power rails deliver more    headroom, deeper lows, smoother highs and an overall fuller sound.
    Discrete - No op amps. Only transistors, resistors and capacitors. Op amps add noise, coloration and harshness to a signal. Discrete designs deliver ultra low noise and transparency.
    Class A - When a circuit is running in Class A mode the circuit is always in an "on" state operating at its optimal voltage requirements. Class A mode has zero crossover distortion and delivers purer, clearer and more musical sonics than class A/B designs which are found in most op-amp circuits.
The net result of the XMAX preamp design is high headroom, low noise, wide dynamic range and wide frequency range, and most importantly, musicality and transparency - smooth highs, solid deep lows, and everything in between.
Digital Converters and JetPLL Sync
The FireStudio Project touts A/D/A converters with a dynamic range of over 114dB for unbelievable clarity as well as synchronization using patented JetPLL™ jitter reduction technology. JetPLL™ incorporates noise shaping to virtually remove all audio band jitter. JetPLL™ ensures the highest converter performance possible, resulting in better stereo separation and clearer more transparent audio. JetPLL™ delivers ultra-fast locking to any digital format through a wide range of frequencies and is extremely robust and tolerant of wide variations in clock frequencies. JetPLL™ ensures near perfect clock performance when networking audio devices, thus creating the most stable and robust synchronization to the computer.
Universal Control
Like all members of the FireStudio family of interfaces, including the StudioLive 16.4.2 mixer, come bundled with Universal Control software. Universal Control is a powerful, flexible, and easy to use control-panel application that allows you to daisy-chain to up to 4 FireStudio-family devices for a maximum of up to 52 inputs and outputs.
Universal Control consists of the Launch window and the Device window. In the Launch window, you can set the sample rate, clock source, safe mode, buffer size (PC only), and WDM routing (PC only) for all connected FireStudio-series interfaces. Each device is listed at the bottom of the window, along with Device Window buttons that open each interface’s Device window.
The Device window provides level and routing controls for each FireStudio-series interface’s internal mixer, enabling you to set up zero-latency monitor mixes. Input and output metering have been optimized for ultra-fast screen display and minimum CPU usage, and you can give each interface a custom name. You can use any device in the chain as the master clock source, or you can slave the entire chain to an external digital device using any of the available digital inputs in the chain.
Studio One Artist—Plus Gigabytes of Creative Resources
The FireStudio Project is bundled with an exceptional software package, featuring PreSonus Studio One Artist, the amazing new DAW software for Mac OS X and Windows XP and Vista that makes producing high-quality projects easier than ever before. As part of the Studio One Artist package, you get 20 new PreSonus Native Effects plug-ins and virtual instruments and a generous bundle of third-party loops, software, and instrument sounds.
Compare Studio One Artist & bundled extras to what comes with competing mobile interfaces:
  • All-meat, no-bloat, music-creation software with an intuitive, practical, single-window interface
  • Unlimited tracks, insert effects, sends, virtual instruments, buses, and effects channels
  • Powerful drag-and-drop functionality
  • Content browser with convenient sort options and preview player
  • Full-featured, flexible automation
  • Powerful real-time auto/manual time-stretching and resampling engine
  • Control Link™ (advanced MIDI mapping made easy)
  • Twenty 32-bit Native Sound™ plug-ins, including reverbs, amp modeling, and EQ
  • Four new virtual instruments, including a sampler and an analog-type subtractive synth
  • Ability to control the software mixer in any FireStudio-series interface to create zero-latency cue mixes.
  • Gigabytes of third-party resources, including Native Instruments™ Kore™ Player with custom SoundPack (150 instruments), Native Instruments™ Guitar Rig LE, Toontrack™ EZDrummer Lite, and over 1.4 GB of loops!
    • BrandPreSonus
    • ModelFireStudio Project
    • Part Number246-2504
    • UPC673454000768
    • Product CategoryRecording Interfaces
    • Weight8.5 lbs.
    View similar products to the PreSonus FireStudio Project 10x10 Firewire Interface
    in the Recording Interfaces product category.
