PreSonus DigiMax D8 8-Channel Mic Pre with ADAT outputs
Brand:|Model: DigiMax D8|Part # 246-2534
The DigiMax D8 is an 8 channel preamplifier featuring 8 award-winning class A XMAX mic preamps with 24-bit ADAT digital output. All eight preamps include variable trim control, 48V phantom power, ultra-fast acting LED metering and 20 dB pad.
Part # 246-2534
  • 8 XMAX class A microphone preamps w/ trim control
  • 24-bit resolution ADAT digital output
  • 44.1 and 48K sampling rates
  • External sync via BNC word clock input
  • Direct outputs on every channel
  • LED input metering
  • -20 dB Pad on every channel
The DigiMax D8 is an 8 channel preamplifier featuring 8 award-winning class A XMAX mic preamps with 24-bit ADAT digital output. All eight preamps include variable trim control, 48V phantom power, ultra-fast acting LED metering and 20 dB pad. In addition, 2 instrument inputs are located on the front panel for direct Hi-Z instrument input. Balanced TRS direct analog outputs are located on the rear panel for routing and flexibility. The DigiMax D8 also includes word clock sync input for ultra-low jitter and robust synchronization. The DigiMax D8 is the perfect solution to add eight professional microphone preamplifiers to any digital recording system with ADAT optical lightpipe expansion capability including Digidesign's HD and 003 systems, RME, YAMAHA, Alesis, Mackie, and many others.
8 XMAX Class A PreamplifiersThe DigiMax D8 includes eight custom-designed high-voltage, discrete, XMAX Class A microphone preamplifiers for all types of microphones. The job of a microphone preamplifier is to boost microphone level signals to line level so that the signal can be converted from analog to digital. This mic to line boost is generally a preamplification of over 400 times the voltage of the original mic level signal. This preamplification stage is one of the most important stages that the signal will go through before converted to digital, and is why a high performance preamplifier is important to achieving great results.
  • BrandPreSonus
  • ModelDigiMax D8
  • Part Number246-2534
  • UPC673454000089
  • Product CategoryMicrophone Preamps
  • Weight4.75 lbs.
View similar products to the PreSonus DigiMax D8 8-Channel Mic Pre with ADAT outputs
in the Microphone Preamps product category.
