PreSonus Central Station Studio Control Center
Brand:|Model: Central Station|Part # 246-2550
The Central Station features three sets of stereo analog inputs to switch between input sources such as: DAW, mixer, CD/DAT/Tape player, or keyboards/samplers.
Part # 246-2550
  • Passive Audio Path - no op amps or IC's in main audio path
  • Five stereo inputs (2 digital and 3 analog)
  • 24-Bit/192 kHz DAC (>117 dB dynamic range) via SPDIF and TOSLINK
  • Three sets of monitor outputs; each with passive volume control
  • Talkback microphone with volume to feed headphone and cue output
  • Accurate dual 30-segment LED for metering
  • Two front panel headphone jacks with separate volume control
The Central Station is the ultimate studio-monitoring interface for the modern digital studio. The Central Station features three sets of stereo analog inputs to switch between input sources such as: DAW, mixer, CD/DAT/Tape player, or keyboards/samplers. Two stereo analog inputs feature TRS balanced and the third stereo input features RCA inputs with trim control for level matching of input signals. In addition, the Central Station will accommodate two digital inputs via S/PDIF or TOSLINK providing D/A conversion up to 24Bit/192 kHz. This allows you to monitor DAW and CD/DAT outputs through the same professional quality converter for the most accurate A/B comparison and highest quality monitoring environment. The digital to analog converter offers the highest possible audio quality with over 117 dB dynamic range and ultra high quality analog circuitry. The Central Station features three sets of monitor outputs, each with their own set of passive trim controls. The monitoring section also provides MUTE, DIM and MONO switches. In addition, the Central Station includes a set of CUE outputs that can feed headphone amplifiers and a separate stereo MAIN line level output.
Purely Passive Signal Path
The Central Station features a Purely Passive Signal Path for ultimate sonic performance. The main audio path of the Central Station uses no amplifier stages including op amps or active IC's (integrated circuits) that add noise, color, distortion, and give that "pinched" sound. Distortion produced by op amps and IC's also gives added ear fatigue.
Signal routing in the Central Station is achieved utilizing 34 sealed mechanical relays (instead of active IC's) maintaining a minimal signal path design wherein extraneous electronics are hard-wire bypassed. Using relays ensures the most transparent signal path maximizing dynamic range, frequency range, and headroom, while minimizing noise and coloration. The Central Station uses the highest quality passive components including military grade 1% tolerance metal film resistors, multi-element potentiometers and ultra-durable connectors to deliver the highest sonic performance.
  • BrandPreSonus
  • ModelCentral Station
  • Part Number246-2550
  • UPC673454000508
  • Product CategoryMonitoring & Controllers
  • Weight10.5 lbs.
View similar products to the PreSonus Central Station Studio Control Center
in the Monitoring & Controllers product category.
