246-2530_ALT_0
246-2530_ALT_1
246-2530_ALT_2
246-2530_ALT_3
PreSonus ADL600 High Voltage 2-Channel Tube Mic Preamp
Brand:|Model: ADL600|Part # 246-2530
The ADL600 utilizes a unique high voltage, Class A discrete design with three vacuum tubes per channel for maximum headroom and tonality.
Part # 246-2530
  • High-voltage class A dual transformer design
  • >73 dB gain
  • Selectable microphone input impedance
  • Switched gain and variable fine trim controls
  • Microphone, instrument and line inputs
  • Ultra low noise (-100 dB S/N ratio)
  • Variable high pass filter, 48V, -20 dB pad, polarity invert
The ADL600 is a high voltage two-channel original microphone preamplifier designed by world-renown analog tube circuit designer Anthony DeMaria. The ADL600 utilizes a unique high voltage, Class A discrete design with three vacuum tubes per channel for maximum headroom and tonality. The ADL600 is built by hand in the USA by PreSonus and utilizes the finest components in the world including switched attenuators, carefully pre-tested vacuum tubes, analog VU and LED meters, custom-designed proprietary transformers, and the list goes on. No expenses are spared with the ADL600 down to the last polypropylene film capacitor. The ADL600 is big, warm, smooth, and clear; a sound like no other.
Specifications: • Gain Range • Microphone (1,500 ohm, +20 dB Pad out): 18 to 72 dB • Balanced line: -12 to 40 dB • Instrument: -5 to 42 dB • Noise floor (all inputs, minimum gain): -95dBu (A-weighted) • Microphone equivalent input noise (EIN): -125dBu (A-weighted) • Frequency response: 0 Hz to 45 kHz +/- 1 dB • Maximum output level: +23dBu (@ 0.5%THD+N) • Output impedance: 600 ohm • Tube complement (per channel): 1-12AT7A, 2-6922 • Dimensions: 3.5" H x 17.0" D x 19.0" W.
  • BrandPreSonus
  • ModelADL600
  • Part Number246-2530
  • UPC673454000560
  • Product CategoryMicrophone Preamps
  • Weight25 lbs.
View similar products to the PreSonus ADL600 High Voltage 2-Channel Tube Mic Preamp
in the Microphone Preamps product category.
Videos
