268-378_ALT_0
Precision Port PSP-4DOFH Dimpled 4" Outside Flare for Port Tube
Brand:| Model: PSP-4DOFH
The Precision Portâ„¢ "Create Your Own Port" system allows you to build your own custom length port to your needs using parts made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
  • Create custom 4" Precision Ports
  • Reduces port noise even more than standard flares for clean bass output
  • Sturdy ABS construction made to tight tolerances
268-378
Weight: 0.36 lbs.
OUT OF STOCK
Due In: 4/30/2014
List Price$11.99
You Save34%
$7.87
Buy 4-up$7.00
Part # 268-378
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
The PSP-4DOFH 4" dimpled outside flare reduces air turbulence even further than standard flared ports, rendering port noise inaudible at even high output SPL levels. The outside flare is built with four holes pre-drilled for mounting purposes.
The dimpled PSP-4DOFH 4" outside flare is designed to work with the 4" connecting ring (PSP-4RG) when used with the 4" x 12" port tube (PSP-4TB). Finish off your port tube with the dimpled 4" inside flare (PSP-4DIF) for even more port noise reduction. You can additionally connect inside and outside flares directly to one another using the connecting ring.
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • Outside diameter: 7-1/2" • Cutout diameter: 6-1/2" • Overall length: 3" • Usable length (due to flare): 2-1/2".
  • BrandPrecision Sound
  • ModelPSP-4DOFH
  • Part Number268-378
  • UPC848864000558
  • Product CategorySpeaker Port Tubes
  • Weight0.36 lbs.
View similar products to the Precision Port PSP-4DOFH Dimpled 4" Outside Flare for Port Tube
in the Speaker Port Tubes product category.
Customer projects that include: Precision Port PSP-4DOFH Dimpled 4" Outside Flare for Port Tube
