Precision Port PSP-3OFH 3" Outside Flare for Port Tube
Brand:|Model: PSP-3OFH|Part # 268-368
The Precision Port™ "Create Your Own Port" system allows you to build your own custom length port to your needs using parts made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products.
List Price$5.99
You Save34%
$3.94
Buy 4+$3.70
Part # 268-368
  • Create custom 3" Precision Ports
  • Reduces port noise for clean bass output
  • Sturdy ABS construction made to tight tolerances
  • Proudly made in the USA!
Now you can create your own custom length Precision Port™! Each piece is interchangeable and made to the same exact standards and tolerances of the original, high performance injected and extruded molded ABS port tube kits from Precision Sound Products. Proudly made in the USA!
The PSP-3OFH 3" outside flare reduces the turbulence associated with other vents and port tubes by slowing down the vent air velocity, rendering port noise inaudible. The outside flare is built with four holes pre-drilled for mounting purposes.
The PSP-3OFH 3" outside flare is designed to work with the 3" connecting ring (PSP-3RG) when used with the 3" x 12" port tube (PSP-3TB). Finish off your port tube with the 3" inside flare (PSP-3IF) for even more port noise reduction. You can additionally connect inside and outside flares directly to one another using the connecting ring.
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • Outside diameter: 6-1/4" • Cutout diameter: 5-1/4" • Overall length: 3" • Usable length (due to flare): 2-1/2".
  • BrandPrecision Sound
  • ModelPSP-3OFH
  • Part Number268-368
  • UPC848864000497
  • Product CategorySpeaker Port Tubes
    (1 Reviews)
  • Weight0.23 lbs.
View similar products to the Precision Port PSP-3OFH 3" Outside Flare for Port Tube
in the Speaker Port Tubes product category.
