Power-Sonic PS-1250F2 Sealed Lead Acid Battery 12V 5Ah
Brand:|Model: PS-1250F2|Part # 140-364
High-quality sealed lead acid (SLA) batteries from Power-Sonic provide excellent value for uses including computer UPS systems, alarm back-up, garden tractors, children's vehicles, and many more. The PS-1250F2 has a rated output of 12V, 5 Ah.
List Price$26.25
You Save42%
$15.33
Buy 4+$14.57
Part # 140-364
  • Dimensions: 3.54" L x 2.76" W x 3.98" H
  • Sealed construction requires no maintenance
  • Replaces Panasonic LC-R125P
Power-Sonic PS Series rechargeable sealed lead acid batteries are leaders in their field. They adhere to industry-standard form factors, but lead the way in high tech features and competitive pricing.
Each battery uses valve regulated, spill-proof construction, and is made of rugged ABS plastic, allowing for safe operation in any position. While these batteries have an extended shelf life and may be quite useable up to one year after being charged, Power-Sonic recommends recharging at least once every six months for maximum battery life. The PS Series are humidity-resistant and can be discharged over a temperature range of -40° F to +140° F. Connection by F2 quick disconnect (0.25" x 0.032").
  • Voltage12V
  • Capacity5 Ah
  • BrandPower-Sonic
  • ModelPS-1250F2
  • Part Number140-364
  • UPC813340010413
  • Product CategorySealed Lead Acid Batteries
    (5 Reviews)
  • Weight4.5 lbs.
View similar products to the Power-Sonic PS-1250F2 Sealed Lead Acid Battery 12V 5Ah
in the Sealed Lead Acid Batteries product category.
Power-Sonic PS-1250F2 Sealed Lead Acid Battery 12V 5Ah is rated 4.8 out of 5 by 5.
Rated 5 out of 5 by from Great shelf lifeI bought this battery over a year ago for my little dirt bike, but never installed it. Last week I discovered that it fits perfectly into my uninterruptible power supply. I installed it and its working great! I'm buying more.
Date published: 2015-07-06
Rated 5 out of 5 by from Good batteryBought this to go in my bike bag. will hook up solar charger and use the pair to charge my cell when going on long trips.
Date published: 2014-03-28
Rated 5 out of 5 by from Excellent batteryThis battery is heavy but what SLA isn't? Other than the obvious this battery is working exactly as described and i couldnt be happier with the performance.
Date published: 2014-03-25
Rated 4 out of 5 by from Good Security System Backup BatteryThe push on terminals are wider than the previous batteries I've used. I didn't want to replace the crimp lugs on the original security system lead wires so I made two adapters.Otherwise this battery is a good value and worthy of a 5-star rating.
Date published: 2012-12-16
Rated 5 out of 5 by from Great battery for my e-callerDrives my home made e-caller FOREVER! LOL. Use with the 50w Pyle PA horn and the dta-2 amp ;)
Date published: 2012-12-04
  • 2016-02-07T07:10CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_140-364, PRD, sort_mostRecent
I am building a garage sterio with a car reciever. I have the ac/dc convertor powering it and it works well but if i unplug it i lose a presets. So can i put this in line with the dc power to the reciever  and just let it charge off of the convertor ?
Asked by: 231pontiac
This would maintain presets, but you would be safer adding in some form of charge controller like a battery tender to keep the battery from overcharging,
Answered by: Chrisf
Date published: 2015-04-10
How can I connect this battery to the Lepai 2020 DC in jack? Also, how long can I expect the battery to last powering the Lepai? Thanks!
Asked by: manoskate1
You can expect 4-6 hour play time with this battery assuming a full charge at moderate volume levels. You will need a DC power cord like the one below in order to connect to the battery.http://www.parts-express.com/21mm-x-55mm-x-112mm-dc-plug-with-6-ft-cord--090-489
Date published: 2014-08-05
I'm planning to use this to power a Lepai 2020. Can the power supply for the Lepai be used to charge this battery? The Lepai converter is 12V, 3 amp. Is there a limit on how long it could be left on the converter due to over-heating/over-charging?
Asked by: BobbyL
Unfortunately the power supply will not act as a charger, you will need a dedicated 12V SLA charger for this. The part number for one we offer is 365-008.
Date published: 2014-05-02
I am looking to replace a home alarm battery (Secure sb1240 12v 4.0Ah). Is the a suitable replacement?
Asked by: bb53chevpro
Yes this will work for a security system backup battery.
Date published: 2013-02-06
wt
I believe you have a wrong wt for this item on the web page
Asked by: Loadtoad
Yes the weight of this battery is actually 3.5 lbs, shipping weight will be closer to 4-4.5 lbs.
Date published: 2013-01-28
  • 2016-02-07T07:58CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_140-364, PRD, sort_recentQuestionsFirst
