361-361_ALT_0
361-361_ALT_1
361-361_ALT_2
Portable 10W COB Type Super Bright LED Work Light Rechargeable Flood Light Lamp Yellow
Brand:|Part # 361-361
How many times have you needed a bright work light, but in a location with no power outlets, or you just didn't need the hassle of dragging out the full-size work light for a small job? We've got you covered with this little 10 watt rechargeable gem!
Part # 361-361
  • Small but mighty 10W LED work light
  • Cordless, rechargeable lithium battery
  • Up to 4 hours use per 8 hour charge
  • Household and automotive chargers included
Frequently Bought Together
Sometimes a flashlight just won't cut it, but schlepping out the big work lights (and the attendant several hundred feet of extension cords, or even worse, the generator) isn't an appealing option, either. The reasons can be many, but the solution to this type of problem is the same: our 10 watt rechargeable LED work light.
Built to last and handy as all get out, you'll wonder how you ever got by without a few of these. A 10 watt COB LED provides much more light than you'd expect from an ultra-compact device such as this, and the adjustable stand allows you to focus all that cool white light on your work, quick, easy, and stable. In addition, this little baby is cordless and rechargeable, so you can put it literally just about anywhere you'd ever want. Working on some wiring or ductwork in the attic or basement? Gotcha covered. Working under the car in the garage? Easy-peasy. Camping or indulging in other outdoorsy activities on the lake, or out in the middle of the deep, dark woods? Bada bing, bada boom. Almost pocket-sized, this little beauty goes anywhere you do.
A standard 110-240 VAC wall outlet charger is included, as is a 12V automotive charging cable, so you can keep it charged and ready to go, even on the go. A long-lasting lithium battery provides up to four hours use on a full eight hour charge, so it won't give out on you in the middle of the job. With the charging port and power switch membrane-sealed against the ingress of dust and other contaminants, you don't have to worry if the job gets dirty.
So bright, so handy, so convenient, you're sure to find hundreds of applications for this light. And at our prices, you can afford to get a few! Keep one in your toolbox, one in your car, one in the closet in case of power outages, the list goes on and on.
Specifications: • LED power rating: 10W • Color temperature: 6000~6500K • Battery: Lithium, 7.4V, 4.4 Ah • Charging time: 8 hours • Running time: 4 hours • Input voltage 8.4 VDC, 1A• Dimensions: 9.05" x 6.5" x 5.7" (230 x 165 x 145 mm) • Weight: 2.45 lbs. (1.1 kg).
  • BrandParts Express
  • Part Number361-361
  • UPC848864013374
  • Product CategoryFlashlights
    (5 Reviews)
  • Weight2.4500 lbs.
View similar products to the Portable 10W COB Type Super Bright LED Work Light Rechargeable Flood Light Lamp Yellow
in the Flashlights product category.
