Platinum Tools EZ-RJPRO HD Crimp Tool
Brand:|Part # 150-701
The EZ-RJPRO HD Crimp Tool is designed for the professional installer and is compatible with all EZ-RJ45 and EZ-RJ12/11 crimp connectors.
List Price$86.95
You Save10%
$78.50
Buy 4+$76.49
Part # 150-701
  • Zero flex frame prevents torque loss during the crimping cycle
  • Tool steel die head assembly provides 360º of connector support during crimp
  • Clean, ultra flush trim on the EZ-RJ45® extended conductors
  • Expanded surface area on contact drivers delivers full, uniform crimp force
  • Built in wire cutter and strippers
The Platinum Tools EZ-RJPRO™ HD Crimp Tool uses the EZRJ45® patented "crimp & trim" system and is designed to handle larger dimensional-sized cables. The EZ-RJPRO HD Crimp Tool is designed for the professional audio/visual, communications, or network installer, and it provides a ratcheted, high leverage, ultra stable platform for consistent, repeatable terminations.
This heavy duty tool is the perfect solution when working with high performance, larger OD cables that are tougher to terminate due to larger wire gauges, thicker, harder insulation on the conductors, and pair separating splines. Not only will you overcome these connectivity obstacles but you can be assured that every crimp termination will meet FCC specifications. Compatible with all EZ-RJ45® and EZ-RJ12/11 connectors.
  • BrandPlatinum Tools
  • Part Number150-701
  • UPC849160001201
  • Product CategoryCrimp Connector Tools
    (6 Reviews)
  • Weight1.25 lbs.
View similar products to the Platinum Tools EZ-RJPRO HD Crimp Tool
in the Crimp Connector Tools product category.
Videos
