150-716_ALT_0
150-716_ALT_1
150-716_ALT_4
Platinum Tools EZ-RJ45 Cat 6+ Connector 100 Pcs.
Brand:|Part # 150-716
Stop wasting time and money using standard connectors. The patented EZ-RJ connectors simplify twisted pair terminations by allowing the wires to be inserted through the connector and out the front. The installer can now easily verify the proper wiring order without having to re-strip wires.
List Price$69.95
You Save10%
$62.66
Part # 150-716
  • Thru holes allow wire pairs to be inserted thru the front of the connector
  • Works with solid or stranded wire
  • Use in category 3, 5, 5E, and 6 compliant data networks
  • Faster terminations
  • FCC compliant, UL rated
Stop wasting time and money using standard connectors. The patented EZ-RJ connectors simplify twisted pair terminations by allowing the wires to be inserted through the connector and out the front. The installer can now easily verify the proper wiring order without having to re-strip wires. Electrical performance of the termination is optimized by pulling the connector down over the cable jacket and seating it tightly in the rear of the connector. Deliver more reliable connections and higher performance every time. The EZ-RJ connectors reduce waste, reduce time, and save money. Crimps must be used with patented EZ-RJ45 Crimp Tool, which crimps and trims in one easy motion. Manufactured in the USA. Note: See related items for required crimp tool.
  • BrandPlatinum Tools
  • Part Number150-716
  • UPC899740000681
  • Product CategoryRJ45 Cat 5 & Cat 6 Connectors
  • Unit of MeasurePK
    (6 Reviews)
  • Weight0.4601 lbs.
View similar products to the Platinum Tools EZ-RJ45 Cat 6+ Connector 100 Pcs.
in the RJ45 Cat 5 & Cat 6 Connectors product category.
Platinum Tools EZ-RJ45 Cat 6+ Connector 100 Pcs. is rated 4.8333 out of 5 by 6.
Rated 5 out of 5 by from The only connector worth buyingI only use EZ connectors now. They make things go so much faster they are worth twice what they cost. Vitrually eliminates redos and save troubleshooting.
Date published: 2015-11-18
Rated 5 out of 5 by from The "Holy Grail" of RJ-45's!!I have been using this product for over 3 years and I used to hate installing these connectors because every 4 of these 1 would not work right, but not any more, I haven't gotten ! wrong since I've worked with these!!!
Date published: 2015-08-15
Rated 5 out of 5 by from Great connectorsWe use these connectors for industrial use using 26 gauge wire as part of special video systems and have never had problems with them. We save time on each assembly and don't have loose wires drop out after crimping.
Date published: 2014-02-03
Rated 5 out of 5 by from Platinum Tools EZ-RJ45 Cat 6+ ConnectorBeen using their Cat 5 connectors for a year now and never had any problems or failures. Wish these had been around several years ago as makes doing cable ends perfect every time. They cost more then regular RJ45 male connectors, but these are easier to use and much quicker to complete ends and you know they will work every time.
Date published: 2009-12-18
Rated 5 out of 5 by from Still GreatOut of my last box of 100, I only had to redo 2 - and only because I wasn't paying attention.
Date published: 2009-03-20
Rated 4 out of 5 by from I Love These Things!Since I started using them, rework has dropped to zero, and I can complete a connection in half the time. So far I have not run into any variety of CAT-anything cable that it won't accomodate.
Date published: 2008-08-13
  • 2016-02-09T06:42CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_150-716, PRD, sort_mostRecent
Videos
