150-710_ALT_0
Platinum Tools EZ-RJ45 Cat 5/5e Connector 100 Pcs.
Brand:|Part # 150-710
Stop wasting time and money using standard connectors. The patented EZ-RJ connectors simplify twisted pair terminations by allowing the wires to be inserted through the connector and out the front. The installer can now easily verify the proper wiring order without having to re-strip wires.
List Price$64.95
You Save15%
$55.21
Part # 150-710
  • Thru holes allow wire pairs to be inserted thru the front of the connector
  • Works with solid or stranded wire
  • Use in category 3, 5, 5E, and 6 compliant data networks
  • Faster terminations
  • FCC compliant, UL rated
Stop wasting time and money using standard connectors. The patented EZ-RJ connectors simplify twisted pair terminations by allowing the wires to be inserted through the connector and out the front. The installer can now easily verify the proper wiring order without having to re-strip wires. Electrical performance of the termination is optimized by pulling the connector down over the cable jacket and seating it tightly in the rear of the connector. Deliver more reliable connections and higher performance every time. The EZ-RJ connectors reduce waste, reduce time, and save money. Crimps must be used with patented EZ-RJ45 Crimp Tool, which crimps and trims in one easy motion. Manufactured in the USA. Note: See related items for required crimp tool.
  • BrandPlatinum Tools
  • Part Number150-710
  • UPC899740000377
  • Product CategoryRJ45 Cat 5 & Cat 6 Connectors
  • Unit of MeasurePK
    (5 Reviews)
  • Weight0.2801 lbs.
View similar products to the Platinum Tools EZ-RJ45 Cat 5/5e Connector 100 Pcs.
in the RJ45 Cat 5 & Cat 6 Connectors product category.
Videos
