Pioneer TS-W260S4 Champion Series 10" 1200W Mobile Audio Subwoofer 4 Ohm
Brand:|Model: TS-W260S4|Part # 267-2501
Pioneer's new Champion Series subwoofers feature an all-new design and look. The TS-W260S4 10" subwoofer has a maximum power handling of 1,200 watts. Louder, cleaner bass is what the Champion Series is all about.
Part # 267-2501
  • Dual layer, fiber reinforced elastic polymer surround
  • 4-layer voice coil for high power handling
  • Vented pole piece with extended yoke for reduced power compression and longer stroke
  • Over 8 mm of Xmax
Pioneer's Champion Series subwoofers feature an all-new design and look. All areas of performance have been increased over Pioneer's prior generation of subwoofers. 350 watts RMS power handling (1,200 watts max) really gets things cranking on your daily commute. Purpose-built for sealed enclosures from 0.65 to 1.25 cubic feet. Double stacked magnets create a high power motor assembly for a high sensitivity of 93 dB @ 1W/1m.
IMPP Composite Seamless Cone
An extremely durable, yet lightweight cone is vital to prevent a cone failure at high sound pressure levels. Pioneer's new IMPP composite seamless cone meets this need perfectly while delivering accurate yet powerful bass and increasing sensitivity.
Dual-layer Elastic Polymer Surround
Another world's first from Pioneer. The dual-layer elastic polymer surround dramatically improves durability and lightness for superior response, especially at louder volumes. It also prevents against fatigue created by the extreme temperature swings present in car audio environments.
Larger Surface Area
It's been said that "there's no replacement for displacement", and that's especially true with regards to bass. A speaker's cone is the single most important element in a speaker, as it directly vibrates air that then travels sound to listeners’ ears. Pioneer's Champion Series subwoofer cones have 14% more surface area than conventional subwoofer cones for louder bass reproduction.
Vented Pole Piece
Pioneer designed the Champion Series with a vented pole piece to promote movement of air within the subwoofer. The vent is smoothly channeled for optimal ventilation to ensure a quick response and clear reproduction of bass, reducing the compression that results from trapped air during heavy bass passages.
Includes six 1-1/8" self-tapping screws and an adhesive-backed foam gasket.
  • Nominal Diameter10"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)1200 Watts
  • Impedance4 ohms
  • Frequency Response20 to 250 Hz
  • Sensitivity93 dB 1W/1m
  • Magnet Weight53 oz.
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)2.81 mH
  • Mechanical Q (Qms)12.07
  • Electromagnetic Q (Qes)1.27
  • Total Q (Qts)1.15
  • Compliance Equivalent Volume (Vas)0.47 ft.³
  • BL Product (BL)12.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)148g
  • Maximum Linear Excursion (Xmax)8.1 mm
  • Cone MaterialPoly Composite
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.9375"
  • Baffle Cutout Diameter9.25"
  • Depth5.5"
  • Bolt Circle Diameter10.1875"
  • # Mounting Holes6
  • Sealed Volume0.88 ft.³
  • Sealed F341 Hz
  • Vented Volume3.8 ft.³
  • Vented F325 Hz
  • BrandPioneer Electronics
  • ModelTS-W260S4
  • Part Number267-2501
  • UPC884938188203
  • Weight10.667 lbs.
View similar products to the Pioneer TS-W260S4 Champion Series 10" 1200W Mobile Audio Subwoofer 4 Ohm
