Pioneer TS-SWX251 10" Shallow Mount Loaded Subwoofer Enclosure 4 Ohm
Brand:|Model: TS-SWX251|Part # 267-2517
Pioneer's shallow mount TS-SWX251 loaded subwoofer enclosure features a unique, spider-less subwoofer for fatigue-free performance. The 5-7/8" deep design fits many trucks and sports cars.
Part # 267-2517
  • Get deep big bass from a small enclosure
  • 5-7/8" max depth is great for trucks and sports cars
  • Innovative subwoofer design removes the spider for great durability to linearity
Air Suspension Excursion Control System
In order to create a subwoofer that is three and a quarter inches deep, Pioneer had to develop revolutionary subwoofer technology when creating the TS-SWX251. A traditional subwoofer uses a spider to keep the speaker's voice coil center-aligned while it moves. This type of subwoofer becomes soft over time, degrading the subwoofer’s performance.
To battle this, Pioneer created a patent-pending air suspension system that locks air between a main cone and a drive cone. The cones move together in unison, with the locked-in air behaving like a spring. The dual-cone, spider-less design maintains better sound linearity, and reliability, even after many of hours of hard use. The pressure from the trapped air results in a consistent bass response across a wide frequency range, resulting in a tight, precise movement with powerful and clean bass output.
Angled Push Terminals
Traditional subwoofer terminals are mounted horizontally or vertically, forcing wires to be bent to fit. This can be difficult if large gauge, high performance wires are used. The Pioneer shallow subwoofer’s patent-pending, angled push terminals make it easy to connect speaker wires. The straighter connection saves space and makes installation easier.
Downfring Subwoofer Technology
By directing the subwoofer diaphragm downward, the TS-SWX251 radiates bass with superior efficiency for richer, deeper low-frequency sound regardless of the enclosure’s installed position. Thanks to its innovative enclosure design, the TS-SWX251 enclosure can be installed freely in the cabin or luggage area for optimal utilization of space. Compact space-saving dimensions make it easy to install the subwoofer in a variety of trucks and sports cars.
Specifications: • Power handling: 200 watts RMS/800 watts max • Impedance: 4 ohms • Frequency response: 20-114 Hz • Sensitivity: 89 dB 1W/1m • Dimensions: 18-5/8" L x 12" H x 5-7/8" D.
  • BrandPioneer Electronics
  • ModelTS-SWX251
  • Part Number267-2517
  • UPC884938126892
  • Product CategoryLoaded Subwoofer Boxes
  • Weight21 lbs.
View similar products to the Pioneer TS-SWX251 10" Shallow Mount Loaded Subwoofer Enclosure 4 Ohm
in the Loaded Subwoofer Boxes product category.
