Pioneer TS-SW3001S2 12" 1500W Shallow Mount Subwoofer 2 Ohm
Brand:|Model: TS-SW3001S2|Part # 267-2515
Choose Pioneer's TS-SW3001S2 shallow mount 12" subwoofer for space limited installations where you want a ton of bass, the two ohm impedance extracts maximum power from high current amplifiers.
Part # 267-2515
  • Basalt fiber cone technology for rigidity and natural sound
  • Less mounting depth than most other 12" subwoofers
  • High 400 watts RMS power handling, 1,500 watts max
Pioneer's TS-SW3001S2 12" shallow mount subwoofer is designed to provide wider installation options for a broad range of vehicles. The two ohm TS-SW3001S2 features multiple patent-pending features to deliver the big bass performance of a full-size subwoofer, but in a compact design that can be installed either behind or under seats depending on the type of vehicle. The mounting depth is just 3-1/4", which is less than that of a typical subwoofer in this class.
This 12" shallow subwoofer handles 1,500 watts max, 400 watts RMS, and delivers deep bass with top-notch sound quality thanks to features like Pioneer's extremely strong and lightweight cone, the patent-pending surround, and more. Compatible with sealed enclosures as small as 0.5 cubic feet.
To ensure that you get more natural bass, Pioneer incorporates a new Basalt fiber technology into their shallow subwoofers. The volcanic-rock fibers create a cone that is lightweight, rigid, well damped, stable in temperature extremes, and more environmentally friendly. In short, this bass really rocks.
One of their new patent-pending features is called the "Air Suspension Control System". This design locks air in-between the main cone and drive cone, ensuring smoother and more precise movement of the cones, for superior linearity. The locked-in air behaves like a spring, so there's no need for a traditional spider structure. The drive cone also deflects air pressure inside the enclosure, which further contributes to the remarkable bass of the small package.
Includes eight self-tapping screws for subwoofer mounting.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)1500 Watts
  • Impedance2 ohms
  • Frequency Response20 to 230 Hz
  • Sensitivity93 dB 1W/1m
  • Magnet Weight72 oz.
  • Resonant Frequency (Fs)36.8 Hz
  • DC Resistance (Re)1.5 ohms
  • Voice Coil Inductance (Le)1.3 mH
  • Mechanical Q (Qms)13.21
  • Electromagnetic Q (Qes)0.88
  • Total Q (Qts)0.82
  • Compliance Equivalent Volume (Vas)0.634 ft.³
  • BL Product (BL)10.83 Tm
  • Diaphragm Mass Inc. Airload (Mms)256.62g
  • Maximum Linear Excursion (Xmax)8.4 mm
  • Cone MaterialPoly Composite
  • Overall Outside Diameter13"
  • Baffle Cutout Diameter11"
  • Depth3.25"
  • # Mounting Holes8
  • Sealed Volume1.76 ft.³
  • Sealed F337 Hz
  • Vented Volume2.68 ft.³
  • Vented F321 Hz
  • BrandPioneer Electronics
  • ModelTS-SW3001S2
  • Part Number267-2515
  • UPC012562945750
  • Weight15.55 lbs.
View similar products to the Pioneer TS-SW3001S2 12" 1500W Shallow Mount Subwoofer 2 Ohm
in the Car Subwoofer Speakers product category.
