Pioneer TS-SW251 10" Shallow-Mount Subwoofer
Brand:|Model: TS-SW251|Part # 297-290
Pioneer's TS-SW251 10" subwoofer is designed to last longer with an air suspension system that maintains better sound after many hours of hard use.
Part # 297-290
  • Get deep big bass from a small enclosure
  • Easy to install in virtually any vehicle
  • IMPP composite cone woofer
  • Dual 3-layer fiber-woven radial surround
  • 4-layer long-excursion voice coil
  • Extended and vented pole yoke
Frequently Bought Together
In order to create a subwoofer that is three and a quarter inches deep, Pioneer had to develop revolutionary subwoofer technology. A traditional subwoofer uses the spider design to keep the voice coil of the speaker aligned while it moves. This type of set-up can become soft over time degrading the subwoofer's performance.
Pioneer created a patent-pending air suspension system that locks air between a main cone and a drive cone. The cones move together in unison, with the locked-in air behaving like a spring. The dual-cone structure is a spider-less design that maintains better sound linearity, and reliability even after many of hours of hard use. The pressure from the trapped air results in a consistent bass response across a wide frequency range. The result is a tight, precise movement with powerful and clean bass output.
The shallow subwoofer incorporates an innovative woven cloth reinforced radial urethane surround for improved power handling, reduced distortion, improved durability, and louder, more controlled bass. The surround is constructed of three layers — two of urethane and one of interwoven cloth. The interwoven cloth distributes strength throughout the surround material and improving its high power capability. The result is an extremely durable and resilient surround that resists puckering, even under intense power conditions.
Unlike traditional surrounds that use a single arch shape design, the Pioneer Shallow Subwoofer utilizes a patent-pending M-shape surround that provides superior sound linearity. The M-shape surround also has a lower height, and a lower fc or tuning frequency. The lower fc threshold translates to better and longer performance at lower frequencies.
Traditional subwoofer terminals are mounted horizontally or vertically. These mounts force wires to be bent to fit which can be difficult if low-gauge high performance wires are used. The Pioneer shallow subwoofer's patent-pending, angled push terminals make it easy to connect speaker wires. The straighter connection saves space and makes installation easier.
Traditional subwoofers push air downward. This creates a loading effect or area of pressure underneath the speaker which hampers performance and responsiveness. The rear of the powerful and slim Pioneer shallow subwoofer is designed with specially-shaped fins that channel the airflow sideways instead of downward. Air is continuously pushed in a circular motion, eliminating the loading effect or unwanted pressure of air behind the cone.
  • Nominal Diameter10"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)800 Watts
  • Impedance4 ohms
  • Frequency Response20 to 144 Hz
  • Sensitivity89 dB 1W/1m
  • Voice Coil Diameter2"
  • Magnet Weight36.33 oz.
  • Resonant Frequency (Fs)41.3 Hz
  • DC Resistance (Re)3 ohms
  • Voice Coil Inductance (Le)2.4 mH
  • Mechanical Q (Qms)9.87
  • Electromagnetic Q (Qes)1.15
  • Total Q (Qts)1.09
  • Compliance Equivalent Volume (Vas)0.35 ft.³
  • BL Product (BL)11.78 Tm
  • Diaphragm Mass Inc. Airload (Mms)206.57g
  • Maximum Linear Excursion (Xmax)6.6 mm
  • Cone MaterialCarbon Fiber
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter11"
  • Baffle Cutout Diameter9.36"
  • Depth3.13"
  • # Mounting Holes6
  • Sealed Volume0.38 ft.³
  • Sealed F343 Hz
  • Vented Volume2.43 ft.³
  • Vented F323 Hz
  • BrandPioneer Electronics
  • ModelTS-SW251
  • Part Number297-290
  • UPC012562882055
  • Product CategoryCar Subwoofer Speakers
    (3 Reviews)
  • Weight9.67 lbs.
View similar products to the Pioneer TS-SW251 10" Shallow-Mount Subwoofer
in the Car Subwoofer Speakers product category.
