Pioneer TS-A1605C A Series 6-1/2" 2-Way Mobile Audio Component Speaker System
Brand:|Model: TS-A1605C|Part # 267-2571
Pioneer's A Series component speaker system provides an instant upgrade to "premium" factory speakers. The TS-A1605C 6.5" component speaker system adds the sound stage and imaging that stock speakers simply can't provide.
  • 6-1/2" multi-layer mica cone woofers with phase plugs
  • 3/4" fabric dome tweeters with two mounting options
  • Two 2-way crossovers included
  • 34 to 32,000 Hz frequency response and 60 watts RMS power handling
Absolute fidelity to the music source requires speakers to reproduce not only instruments and vocals, but also the subtle cues within the ambiance of the recording location. Stage size, musicians' movement, aural reflection and other distinctive details all bring sound to life.
Loud And Clear Woofers
Various materials are carefully combined to develop a diaphragm of extra lightness and rigidity to reproduce sound clearly with outstanding responsiveness sensitivity and a suitable degree of internal loss. The new A Series woofers feature a multilayer mica matrix cone where a surface containing mica properly maintains the cone's superior rigidity and internal loss while another layer makes excellent use of light, water-resistant material.
The TS-A1605C woofer has a cone that is 14% larger than conventional 6-1/2" speakers, yet fits into the exact same cutout dimensions. The result is deeper low range sound reproduction. A machined phase plug is added for superior off-axis midbass and midrange response while forcing the cone travel to remain linear.
Completely Redesigned Tweeters
For a smooth off-axis response, the TS-A1605C component speakers include a soft dome tweeter that is loaded into a waveguide that projects its output in a uniform, wide dispersion pattern.
Fabric is used for the tweeter's diaphragm and is optimized to balance light weight (for great transient response) with rigidity, so that it achieves outstanding sound propagation with high sensitivity, speed, and responsiveness.
This newly developed tweeter disperses sound more widely with superior control, providing listeners with the best sound under all conditions, regardless of listening position or car. Pioneer also extends tweeter performance to much lower frequencies, creating a wider response with fuller fidelity and clear, accurate vocals, while integrating better with the woofer.
Specifications: • Power handling: 60 watts RMS/350 watts peak • Impedance: 4 ohms • Frequency response: 34-32,000 Hz • SPL: 90 dB • Woofer dimensions: Overall diameter (with grill): 7-1/4" dia., Cutout: 5" dia., Mounting depth: 2-1/8" • Tweeter dimensions: Dome size: 3/4" dia., Flush mount cutout: 1-3/4" dia., Flush mount depth: 3/4" • Crossover dimensions: 2-1/2" L x 1-5/8" W x 7/8" H.
Inside the box you'll find:
• Two 6-1/2" woofers
• Two woofer grills
• Two 3/4" tweeters with 10" wiring harness pre-attached
• Two crossovers
• Four tweeter mounting rings (two flush, two angled)
• Two 1/2" self-tapping screws
• Eight 1" self-tapping screws
• Eight speed clips
• Two adhesive backed foam pads
• Owners manual
  • BrandPioneer Electronics
  • ModelTS-A1605C
  • Part Number267-2571
  • UPC884938187459
  • Product CategoryComponent Speaker Systems
  • Weight5.3000 lbs.
View similar products to the Pioneer TS-A1605C A Series 6-1/2" 2-Way Mobile Audio Component Speaker System
in the Component Speaker Systems product category.
