Pioneer SP-SB23W Speaker Bar System with Wireless Subwoofer and Bluetooth Connectivity
Brand:|Model: SP-SB23W |Part # 250-654
The Pioneer SP-SB23W speaker bar system, designed by Andrew Jones, upgrades your TV's sound to audiophile quality in a simple and impressive package.
- Order Soon - Only 3 Left In Stock
List Price$449.99
You Save11%
Part # 250-654
  • Composite wood curved cabinet
  • Four 3" structured surface mid-woofers
  • Two 1" soft dome tweeters
  • Built-in Bluetooth for wireless streaming
  • Includes wireless 6-1/2" powered subwoofer
  • Simple set-up and usability
Pioneer's SP-SB23W speaker bar system was designed by legendary audio engineer Andrew Jones, specifically for the audio enthusiast seeking an easy-to-use full range system. The speaker bar features a straight forward and simple interface that makes this top-shelf quality system easily accessible for users of all experience levels. Throw in the built-in Bluetooth, IR remote and wireless powered subwoofer, and you've got an unstoppable package at a shockingly affordable price point.
Six Speakers – Six Amplifiers
The SP-SB23W speaker bar utilizes six amplifiers to power each driver. Producing up to 28 watts of power, each amplifier independently drives each speaker for a great overall dynamic response. By doing this, the speaker bar enhances the overall headroom at any volume. The speakers included in the sound bar are four 3" structured surface mid-woofers and two 1" soft dome tweeters. The woofers are created with a vented pole piece and structured surface cone, improving the normal performance of a typical 3" woofer.
Wireless Subwoofer
This speaker bar system from Pioneer is beautifully rounded off with a wireless powered subwoofer. You have the option of putting this subwoofer anywhere you want to, provided it's near a power outlet. The 6-1/2" subwoofer is powered by a 50 watt plate amplifier built into the box. The level of the subwoofer can be conveniently adjusted by the included remote.
Learning Mode
Included with this package is an IR remote for control and convenience. But if throwing in another remote to the mix isn't your thing, the speaker bar has a learning mode. With this mode you can program your favorite remote to work with this sound bar.
Cabinet Construction
Sound bars in today's market are commonly constructed in plastic enclosures. The SP-SB23W features a composite wood cabinet enclosure that uses a superior RF heated and molded process to achieve the special curved design. This construction style reproduces audio more accurately and clearly.
Easy Setup
Pioneer's speaker bar system is designed specifically to make set-up simple. Minimal cable attachments, wireless powered subwoofer, an easy-to -use interface, and Bluetooth connectivity means that you'll have hi-fi quality sound in a matter of minutes.
Speaker Bar Specifications: • Power output: 6 x 28 watts • Frequency range: 45 - 20,000 Hz • Drivers: 4 x 3" mid-woofers, 2 x 1" tweeters • Inputs: 1 Optical, 1 Analog • Bluetooth: A2DP Wireless • Cabinet construction: CARB2 MDF wood • Wall mountable: yes • Rubber feet: 2 • Dimensions: 35.98" W x 4.05" H x 4.74" D.
Powered Subwoofer Specifications: • Power output: 50 watts • Driver: 6-1/2" woofer • Connection: Wireless 2.4 GHz • Cabinet construction: CARB2 MDF wood • Dimensions: 9.01" W x 10.01" H x 9.01" D.
  • Special FeaturesBluetooth Wireless,Powered,Speaker Bar
  • Woofer Diameter3"
  • ColorBlack
  • BrandPioneer Electronics
  • ModelSP-SB23W
  • Part Number250-654
  • UPC012562907314
  • Product CategorySound Bars / Speaker Bars
    (2 Reviews)
  • Weight28.0000 lbs.
View similar products to the Pioneer SP-SB23W Speaker Bar System with Wireless Subwoofer and Bluetooth Connectivity
in the Sound Bars / Speaker Bars product category.
