Pioneer PRS-D800 2-Channel 600W Max Power Class FD Audiophile Mobile Audio Amplifier
Brand:|Model: PRS-D800|Part # 267-1905
Take your mobile car audio system to the next level in fidelity with Pioneer's PRS-D800 stereo Class FD mobile audio amplifier. It's not made for everyone, but that's what you'll love about it.
Part # 267-1905
  • Designed for the discerning car audio enthusiast
  • Audiophile-grade components used throughout
  • Includes end caps for a professionally installed look
Pioneer's PRS-D800 is designed for the particular audiophile in much the same way high-end professional amplifiers are built. It forgoes the extra bells and whistles that other amplifiers include (bass boost, crossovers, high to low converters... et cetera) in favor of delivering a pure, clean source of power for your speakers. You may find this amp to be better than most of your home audio gear when all is said and done!
Audiophile Quality Meets Car Audio Mobility
The PRS-D800 two channel amplifier from Pioneer contains audiophile grade components that were carefully selected and design perfected to achieve the highest audio quality possible in the mobile audio environment.
  • High Performance High-Slew Rate Operational Amp: The PRS amplifier includes Linear Technology Corporation's high-performance high-slew rate operational amplifier in the circuitry that generates PWM (Pulse Width Modulation) signals from analog input signals with amazing accuracy. The result: very linear music reproduction with low distortion rate.
  • Capacitors Selected Explicitly for Audio Quality: Extensive listening tests went into selecting each audio capacitor for optimal clarity, frequency response, and dynamic range.  High-end sound tonality and detail were chosen above cost, even when differences were minute.
  • OFC (Oxygen-Free Copper) Wire Coil for Output: The output of the Class-FD amplifier features OFC wire coil for low DC (Direct Current) resistance and low loss, so that speakers can be driven strongly to produce tight bass, a vivid midrange, and crystal clear highs.
  • TVC (Total Vibration Control): Anti-vibration isolation material under the transformer thoroughly eliminates vibration that normally blocks sound when high current is applied, enhancing power flow stability, minimizing distortion, and raising the signal-to-noise ratio.
Compact Design
The ultra-compact design of the PRS-D800 gives you a multitude of installation options. A functionally separated circuit layout and four-layer circuit board are designed to integrate mounted parts, reduce circuit impedance, and maintain high performance and sound quality. The design's efficient heat dissipation is ideal for an amplifier that is compact enough to be installed in various places in a vehicle.
Flexible Connectivity
The PRS amplifier is designed for a sense of unity in parallel connections, allowing for flexible amplifier combinations and installation according to system configuration. A bottom mounted mode switch turns the PRS-D800 from a stereo amplifier (requiring stereo RCA connections) to a mono amplifier (requiring only one RCA connection).
• CEA-2006 certified power output:
            125 watts x 2 (@ 14.4V, 4Ω, ≤1% THD+N)
            300 watts x 1 (@ 14.4V, 2Ω, ≤1% THD+N)
           150 watts x 2 (@ 14.4V, 2Ω, ≤1% THD+N)
• Frequency response: 10 to 30,000 Hz (+0 dB, -3 dB)
• Signal-to-noise ratio:
           105 dB (IHF-A network)
           84 dB (1W @ 4Ω)
• Distortion: 0.004% (4W @ 1 kHz)
• Separation:
           70 dB (10W @ 1 kHz)
           65 dB (10W, 100 to 10,000 Hz)
• Gain control: 400 mV to 6.5V
• Maximum input level: 6.5V
• Input impedance: 22k Ω
• Dimensions (L x W x H): 4-1/8" x 10" x 2"
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)125 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels2
  • BrandPioneer Electronics
  • ModelPRS-D800
  • Part Number267-1905
  • UPC884938153133
  • Product CategoryCar Amplifiers
  • Weight4.5 lbs.
View similar products to the Pioneer PRS-D800 2-Channel 600W Max Power Class FD Audiophile Mobile Audio Amplifier
in the Car Amplifiers product category.
