Pioneer GM-D7500M 800W Class-D Mono Amplifier
Brand:|Model: GM-D7500M|Part # 267-193
Built into the GM-D7500M is a very smart crossover network. It works like a gateway, routing the big bass signals (adjustable from 40 to 240 Hz or lower, at -12 dB/octave) and filtering out higher-frequency signals to that subwoofer.
Part # 267-193
  • Class D amplifier maximizes efficiency while minimizing heat generation
  • Extra-compact design for versatile installation
  • Selectable Bass Boost controls audio balance and impact
  • Class-D design
  • MOSFET output section
  • Compression-type speaker terminals
  • Balanced isolator input circuit
Built into the GM-D7500M is a very smart crossover network. It works like a gateway, routing the big bass signals (adjustable from 40 to 240 Hz or lower, at -12 dB/octave) and filtering out higher-frequency signals to that subwoofer. This optimizes your system's efficiency and delivers the best possible sound quality. 100 % of the power, 45 % of the size. The superior efficiency of a Class-D amplifier means higher power output and greater compactness than an analog amplifier offers. Class-D amplifiers overcome the inefficiencies of traditional Class-A or AB amplifiers. Pioneer’s Class-D amps transform very little power into heat so a higher percentage of the power supply (67 %) is transformed into the load. This results in a very compact amp which needs less input power to produce very high output power. The Class-D amplifier's PWM (Pulse Width Modulator) modulates the original audio input signal with a triangulated signal wave which has a much higher fixed frequency. The result is a digital signal which contains both the input signal and a band of frequency components around the modulation frequency. A LPF (Low Pass Filter) then filters out the high frequency pulses and the resulting amplified output signal is then sent to the subwoofer and/or speakers.
Specifications: • Peak music power: 800 watts • Number of channels: 1 • Load impedance capability: 2~8 ohms • Continuous power (4 ohm): 200 watts x 1 • Continuous power (2 ohm): 400 watts x 1 • Frequency response: 10 Hz ~ 240 Hz • Total harmonic distortion: 0.03% • S/N ratio: 80 dB • Channel # capability: 1 • RCA inputs: 2 channel • Input level control: Hi-Volt (200mV ~ 6.5V) • Built-in crossover: Variable LPF • Crossover frequency range: 40~240 Hz, -12 dB/Oct. • Bass level control: 50 Hz, 0/6/9/12 dB • Warranty: One year • Dimensions: 8-7/8" x 2-1/4" x 7-7/8" (225 x 56 x 200 mm).
  • Input TypeRCA Line Level
  • RMS Power Output (Per Channel 4 Ohms)200 Watts
  • Special Features2 ohm Stable
  • Output Channels1
  • BrandPioneer Electronics
  • ModelGM-D7500M
  • Part Number267-193
  • UPC012562969879
  • Product CategoryCar Amplifiers
    (1 Reviews)
  • Weight4.95 lbs.
View similar products to the Pioneer GM-D7500M 800W Class-D Mono Amplifier
in the Car Amplifiers product category.
