Pioneer GM-3500T 2-Channel 400W Max Power Mobile Audio Amplifier
Brand:|Model: GM-3500T|Part # 267-1900
Pioneer's affordable GM-3500T two-channel amplifier is great for small car audio systems. CEA2006 rated for 60 watts of output from each channel, the GM-3500T is also two ohm stable and bridgeable.
Part # 267-1900
  • 120 watts of CEA2006-rated Class AB power
  • 2 ohm stereo stable and four ohm mono bridgeable
  • Built-in low pass filter and speaker-level inputs
Feel the Difference
From dramatic distinction to dramatic design, Pioneer's GM Series amplifiers are thrillers in every sense, pushing the limits of flexibility and functionality.
The two-channel GM-3500T delivers a whopping 400 watts max, plenty of juice to power your speakers. It's also got a built-in low-pass crossover, speaker level inputs for easy connection to a factory stock car stereo receiver, and oversized power terminals.
CEA2006 Specifications
  • Power Output: 60 watts RMS x 2 Channels (4 ohms ≤ 1% THD+N)
  • Signal-to-Noise Ratio: 80 dBA (Reference: 1 Watt into 4 ohms)
Inspired By Excellence
Pioneer is constantly finding ways to make amplifier technology better. Their new and improved GM Series amplifiers prove that you can add cutting-edge technology and more power to your system without breaking the bank. Like all Pioneer products, these amps are fully tested to ensure that each is designed and built for performance.
Higher Power
Having more power isn't just about loud. It's also about clean, getting the most out of your speakers and your music. Constant road noise makes it hard for the music to be heard clearly. But with 400 watts maximum power, you'll get to hear all the words and all the notes..
High Capacity Switching Power Supply
To suppress power supply loss, GM Series amplifiers incorporate a large toroidal transformer and are driven using a high-speed switching MOSFET. This stabilization of power maintains stable playback of all types of music.
Gain Control
What is power without control? To accommodate the varying range of signal levels coming from today's factory and aftermarket radios, all of Pioneer's GM Series amplifiers feature adjustable gain controls. This means that no matter what kind of radio is connected to this amplifier, the appropriate gain control adjustment can be made to ensure loud, clear, distortion-free music.
And even if the gain control level is set improperly, Pioneer's Gain Control Caution feature will automatically reduce the amplifier's output until the receiver volume is decreased to acceptable levels. This added layer of protection helps to prevent damage from occurring to the amplifier and the speakers connected to it due to improper gain control adjustments.
Bringing The System Together
The GM-3500T's speaker level inputs allow you to connect your factory audio system (or any unit that doesn't have the typical RCA-type inputs) without having to buy add-on adapters. The install goes faster, you save money, and you've got a Pioneer amp in your vehicle.
• RMS power output:
            85 watts x 2 (@ 2Ω, ≤1% THD+N)
            60 watts x 2 (@ 4Ω, ≤1.5% THD+N)
           185 watts x  1 (@ 4Ω)
• Frequency response: 10 to 70,000 Hz
• Crossover (switchable):
            Low pass filter: 80 Hz, -12 dB/octave
• Dimensions (L x W x H): 11-3/8" x 8-5/8" x 2-1/2"
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)60 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels2
  • BrandPioneer Electronics
  • ModelGM-3500T
  • Part Number267-1900
  • UPC884938136365
  • Product CategoryCar Amplifiers
  • Weight5.15 lbs.
View similar products to the Pioneer GM-3500T 2-Channel 400W Max Power Mobile Audio Amplifier
in the Car Amplifiers product category.
