299-680_ALT_0
Philips 314113000201 R TMM 2-Way LCD TV Speaker Module 4 Ohm
Brand:|Part # 299-680
Save over 45% off the discounted retail price, and up to 60% off, on this unique LCD TV speaker module from Philips through this Parts Express exclusive buyout.
Comparable Items In Stock:
Part # 299-680
  • Unique TMM (tweeter, mid, mid) design with passive radiator
  • Smooth frequency response from 80 to 20,000 Hz
  • Great for use as a stand-alone speaker with an industrial look
  • Use two together to make a great sounding speaker bar
Philips designed this self-contained, TMM (tweeter, mid, mid) 2-way speaker for use in the right side of many different flat panel LCD TVs, from 32" to 50" in size. The durable ABS enclosure is designed to resist heat and shock.
A 1" poly dome tweeter (with a 1/2" dust cap) is mated to two 2" paper cone midwoofers with rubber surround for very good dispersion characteristics. For extended low frequency response, a rear-mounted 1-1/2" wide by 4" long aluminum cone passive radiator, with rubber surround, tunes the sealed enclosure to 115 Hz.
Speaker connection is provided through a 3/16" male disconnect for positive and a 1/8" male disconnect for negative. Four 3/8" tabs with rubber isolation grommets are provided at each corner of the enclosure for secure mounting.
This speaker module features smooth sound from 80 Hz all the way to 20,000 Hz, making it great for use as a standalone speaker with an industrial look (great for art installations), or as a speaker bar when two are mounted side-by-side.
Save over 45% off the discounted retail price, and up to 60% off overall, through this Parts Express exclusive buyout. Hurry, supplies are limited!
Specifications: • Power handling: 15 watts RMS/30 watts max • Impedance: 4 ohms • Frequency response: 80-20,000 Hz • SPL: 85 dB 1W/1m • Dimensions: 14-3/4" H x 3" W x 7/8" D (at thinnest point), 2-1/2" D (at thickest point).
  • Input Rating4 ohm
  • Special FeaturesWater Resistant,Speaker Bar
  • Woofer Diameter2-1/2"
  • Configuration2-way
  • ColorBlack
  • BrandFactory Buyouts
  • Part Number299-680
  • UPC848864013022
  • Product CategorySound Bars / Speaker Bars
    (30 Reviews)
  • Weight1.5500 lbs.
View similar products to the Philips 314113000201 R TMM 2-Way LCD TV Speaker Module 4 Ohm
in the Sound Bars / Speaker Bars product category.
