Buyout Special
299-680_ALT_0
Philips 314113000201 R TMM 2-Way LCD TV Speaker Module
Save over 45% off the discounted retail price, and up to 60% off, on this unique LCD TV speaker module from Philips through this Parts Express exclusive buyout.
  • Unique TMM (tweeter, mid, mid) design with passive radiator
  • Smooth frequency response from 80 to 20,000 Hz
  • Great for use as a stand-alone speaker with an industrial look
  • Use two together to make a great sounding speaker bar
299-680
Weight: 1.5500 lbs.
IN STOCK
List Price$24.99
Regular Price$19.00
You Save74%
Sale Price
$5.00
Part # 299-680
Philips designed this self-contained, TMM (tweeter, mid, mid) 2-way speaker for use in the right side of many different flat panel LCD TVs, from 32" to 50" in size. The durable ABS enclosure is designed to resist heat and shock.
A 1" poly dome tweeter (with a 1/2" dust cap) is mated to two 2" paper cone midwoofers with rubber surround for very good dispersion characteristics. For extended low frequency response, a rear-mounted 1-1/2" wide by 4" long aluminum cone passive radiator, with rubber surround, tunes the sealed enclosure to 115 Hz.
Speaker connection is provided through a 3/16" male disconnect for positive and a 1/8" male disconnect for negative. Four 3/8" tabs with rubber isolation grommets are provided at each corner of the enclosure for secure mounting.
This speaker module features smooth sound from 80 Hz all the way to 20,000 Hz, making it great for use as a standalone speaker with an industrial look (great for art installations), or as a speaker bar when two are mounted side-by-side.
Save over 45% off the discounted retail price, and up to 60% off overall, through this Parts Express exclusive buyout. Hurry, supplies are limited!
Specifications: • Power handling: 15 watts RMS/30 watts max • Impedance: 4 ohms • Frequency response: 80-20,000 Hz • SPL: 85 dB 1W/1m • Dimensions: 14-3/4" H x 3" W x 7/8" D (at thinnest point), 2-1/2" D (at thickest point).
  • Input Rating4 ohm
  • Special FeaturesWater Resistant,Speaker Bar
  • Woofer Diameter2-1/2"
  • Configuration2-way
  • ColorBlack
  • BrandFactory Buyouts
  • Part Number299-680
  • UPC848864013022
  • Product CategorySound Bars / Speaker Bars
    (20 Reviews)
  • Weight1.5500 lbs.
View similar products to the Philips 314113000201 R TMM 2-Way LCD TV Speaker Module
in the Sound Bars / Speaker Bars product category.
Philips 314113000201 R TMM 2-Way LCD TV Speaker Module is rated 4.7 out of 5 by 20.
Rated 4 out of 5 by from Great sound for dirt cheap!!As others have mentioned, the physical shape- size makes them somewhat awkward for placement. But for the price, they can't be beat! I bought two pair, one for a computer speaker setup, and the other to maybe make a DIY soundbar. A sub is needed to fill out the bottom end. But they really do a great job for mid's and upper end! As always,great customer service, products & prices keep me coming back!
Date published: 2015-01-20
Rated 4 out of 5 by from Worth the 5 bucks...Saw these on the buy-out pages and I thought they looked pretty interesting... dual woofers, passive radiator... decided to spring for a pair (for all of 10 bucks).They are actually not bad... good overall sound, nicely balanced. Don't expect a lot of bass with those small woofers, but hey make a very nice near field speaker... great for casual computer audio.The only drawback is the packaging... they are somewhat difficult to position anywhere.FWIW... at the same time I bought these, I also bought a pair of the new B452s... These Phillips TV speakers are *much* better sounding....
Date published: 2015-01-10
Rated 5 out of 5 by from awesome cheap sound. limited spl'sModule volume 700ml. Radiator glue melts at 190 deg
Date published: 2015-01-07
Rated 5 out of 5 by from Amps & SpeakersI Have Bought 3 Small Amps & A set Of Speakers To Use On My Computers They Have All Worked Great Jest What I Wanted,And The Service Has Been Excellent.The Best Products And Service I Have Seen In A Long Time.
Date published: 2014-12-18
Rated 5 out of 5 by from surprisingly nice sounding w/passiveRecieved these bargains a day ago. Hooked them up to a Dayton DTA 100 and thought they sounded real nice. Compared them to some 2way Moreltweet /SB mid bookshelf and really other then less bass the Phillips sound great. I liked them. Will make a sound bar with them. Passive speaker really works quite well. Add a small sub and you have saved
Date published: 2014-12-12
Rated 5 out of 5 by from Killer speakers for a variety of purposesGuys - I bought two of these, plus a Lepai LP-2020A+ and figured I could find something clever for them to do. When I got them I was shocked at the sound quality of the combination. Crystalline, lifelike mids and highs, and unsuspected amounts of bass from the radiator - just make sure they are close to a reflective surface (like the TV in the pictures, or a wall) otherwise the bass will drop off substantially.I'm including a picture of what I came up with - the long part that sticks out makes a perfect "base" when cut off, then superglued to the main speaker (point from another guy - there's a letter "R" printed on the long part - if you cut there you will avoid slicing the internal wiring - which is why one box is shorter than the other!)Key point is to seal the main speaker enclosure - I cut 3/4 inch off of the long part and krazy glued those to the small opening to seal the main box, preserving the bass - I'm kind of a hack so it doesn't look polished, but is sounds awesome.I use it as an upgrade to the AV stack in the master bedroom. RCA outputs feed from my TV (which gets volume control from the TV remote) and I use a short 3.5mm extension for the 2nd input, for MP3/ tablets (shown) and other devices.Unbelievable sound upgrade - for DIY'ers, this'll put sound bars or computer speakers out of business!
Date published: 2014-12-05
If i replaced the two 2" with one nd91-4 and put it in a simaler chamber about what lowend frequency would i get?
Asked by: jc19
how close can I put these to a TV w/o have magnetic interference?
Asked by: tlbonehead
If the TV is a flat panel type there is no limit, a magnet will not effect these like an older CRT style television. If it is an older style tube TV, I cannot provide an exact distance but 24" would probably be a close guess.
Date published: 2015-01-19
I want to wire 2 unit in series for 8ohm load, what cap will be a good choice for cut out some low frequency. They are to be use on each side of tv along with a powered sub.
Asked by: skippo
I would recommend a 200 uF cap to help keep the excursion in check.
Date published: 2014-12-31
Are these magneticly sheilded?
Asked by: Stevedrivr
The speakers internally are not shielded
Answered by: TomI
Date published: 2014-10-09
I am going to be designing a very slim enclosure to house both the sealed Philips speakers as well as a woofer for LF. Looking at the Dayton ND105-4 woofer and the Peerless 830878. Will the Philips Passive Radiators affect the Dayton and Peerless setup?
Asked by: ahillelt
Yes it would. The Philips unit would work best mounted open-back, with the Dayton and Peerless mounted in a separate enclosure.
Date published: 2014-10-23
Can you request left and right speakers when purchasing?  Bought 4 of these which have an "R" stamped on the front.  I need to buy the Left version so I can have correct pairs.
Asked by: BConnelly
Unfortunately we only have the right speakers available.
Customer projects that include: Philips 314113000201 R TMM 2-Way LCD TV Speaker Module
Customers Also Bought
