262-350_ALT_0
Penn-Elcom L0925Z Butterfly Latch Surface Mount Zinc
Brand:| Model: L0925Z
Superb quality butterfly latch for a variety of cabinet applications. Manufactured by Penn Fabrication in the UK. * Construction: 1.2mm/.047" steel * Description: Large surface mount butterfly latch (no dish) * Dimensions: 3" x 4.80" * Color: Zinc * Mfg. #L0925Z.
262-350
Weight: 0.5478 lbs.
IN STOCK
$7.48
Buy 10-49 $7.16
Buy 50-up$6.11
Part # 262-350
Penn Fabrication...Supplying The Music Industry Since 1974. Superb quality butterfly latch for a variety of cabinet applications. Manufactured by Penn Fabrication in the UK. * Construction: 1.2mm/.047" steel * Description: Large surface mount butterfly latch (no dish) * Dimensions: 3" x 4.80" * Color: Zinc * Mfg. #L0925Z.
  • Construction MaterialSteel
  • Color / FinishZinc
  • BrandPenn-Elcom
  • ModelL0925Z
  • Part Number262-350
  • UPC844632052859
  • Product CategoryLatches
    (8 Reviews)
  • Weight0.5478 lbs.
View similar products to the Penn-Elcom L0925Z Butterfly Latch Surface Mount Zinc
in the Latches product category.
Penn-Elcom L0925Z Butterfly Latch Surface Mount Zinc is rated 4.625 out of 5 by 8.
Rated 5 out of 5 by from Great LatchI used these on a road case I built for my Carvin C2040 mixer. There is not much to say other than they are top quality pro grade latches that will last for decades
Date published: 2013-03-17
Rated 5 out of 5 by from Does what it is meant to doSturdy and well built-used to make latches for a home made guitar pedal board case. Impossible to find it seems any where else. These get it done right.
Date published: 2010-03-05
Rated 4 out of 5 by from Perfect applicationThis item worked to expectation. I used it to make a steaming box for bending wood
Date published: 2009-10-01
Rated 4 out of 5 by from latch does what it's supposed topulls the two pieces that you're trying to latch together.
Date published: 2009-02-10
Rated 5 out of 5 by from Perfect Solution!I'm building a trailer for transporting dogs to shows and hunt tests - the design has a hinged roof with storage underneath these latches are the perfect solution to lock the roof down when in motion....
Date published: 2009-02-04
Rated 5 out of 5 by from real dealHey these latches ae just what I need for my music equipment cases. My crew went nuts when they saw how heavy duty they were. No more lids and covers falling off when they lift and load things....great stuff..
Date published: 2008-08-08
what is the size (measurements) of the smaller part of this Latch? I have to mount to either 1/2, 5/8 or 3/4" plywood. So only have limited space.
Asked by: Giorgio
The small part of this latch measures 1-1/2" high and 2" wide. The screw holes are in a triangular pattern and are 1-3/8" at the widest center to center and the center screw hole is offset 1/2" from the others.
Date published: 2013-09-14
Customer projects that include: Penn-Elcom L0925Z Butterfly Latch Surface Mount Zinc
