262-334_ALT_0
Penn-Elcom D0604K Dish Two Neutrik D Black 3-1/2" x 5-1/8"
Brand:|Model: D0604K|Part # 262-334
Steel dish pre-punched for mounting two Neutrik "D" Series and/or Speakon NL2/NL4 panel mount connectors.
$4.77
Buy 10-49 $4.24
Buy 50+$3.84
Part # 262-334
Steel dish pre-punched for mounting two Neutrik "D" Series and/or Speakon® NL2/NL4 panel mount connectors . Constructed of heavy-duty 1.2 mm/.047" steel. Black powdercoat finish.
Specifications: • Dimensions: 3-1/2" x 5-1/8" • Requires 2-1/2" H x 4" W cutout • Penn model D0604K.
  • ConfigurationTwo Neutrik D
  • Construction MaterialSteel
  • Color / FinishBlack
  • BrandPenn-Elcom
  • ModelD0604K
  • Part Number262-334
  • UPC844632052750
  • Product CategoryConnector Dishes
    (11 Reviews)
  • Weight0.28 lbs.
View similar products to the Penn-Elcom D0604K Dish Two Neutrik D Black 3-1/2" x 5-1/8"
in the Connector Dishes product category.
Penn-Elcom D0604K Dish Two Neutrik D Black 3-1/2" x 5-1/8" is rated 4.5455 out of 5 by 11.
Rated 4 out of 5 by from Best I have found, but could be improvedThis speakon dish is solidly built and works well. However, it requires additional seals (I use weather stripping). I also think that they need to add a couple more screw holes because it does not stay flush. As long as I put something to seal behind it, it works great though.
Date published: 2012-04-23
Rated 5 out of 5 by from Just like YamahaHey Yamaha uses a plate very simalar to this only they throw in a 1/4 jack...I could care less about the 1/4 jack especially since we are using these on our big 18" subwoofer cabinets.If the pro manufactures are using them then we can get the same professional results with this kind of stuff!
Date published: 2011-09-28
Rated 5 out of 5 by from Simply PerfectWhat could possibly be wrong with it? It is black, has the proper holes, and is made of steel.
Date published: 2009-08-25
Rated 4 out of 5 by from Hey - it's a hunk of metalWhat can say - it works fine and is thick enough grade. Will buy more. Price is reasonable for value.see davidkimmick.com
Date published: 2009-08-21
Rated 5 out of 5 by from Metal is best in live gear applications.Plastic may be easier to install, but metal takes abuse.
Date published: 2008-12-18
Rated 4 out of 5 by from Good dishPretty much your best choice for a dish if you're building cabs or just need to recess connections. The gasket should have been included (262-048) but it's worth the extra few cents so the panel is removable (i've sealed these with silicone in the past). Little overpriced but its a good solid penn product, so you get what you pay for.
Date published: 2008-12-02
  • 2016-02-11T06:47CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_262-334, PRD, sort_mostRecent
