260-772_ALT_0
260-772_ALT_1
260-772_ALT_2
Penn-Elcom 9106 Rubber Cabinet Foot 2.5" Dia. x 1" H
Brand:|Model: 9106|Part # 260-772
Penn-Elcom's 9106 extra-large, heavy-duty rubber foot offers a sure grip on all types of surfaces. Ideal for large rack cabinets, transport cases, or speaker cabinets. Dimensions: 2.5" diameter x 1" high (64 mm x 25.4 mm).
List Price$3.99
You Save55%
$1.78
Buy 10-99 $1.53
Buy 100+$1.41
Part # 260-772
Penn-Elcom's 9106 extra-large, heavy-duty rubber foot offers a sure grip on all types of surfaces. Ideal for large rack cabinets, transport cases, or speaker cabinets. Dimensions: 2.5" diameter x 1" high (64 mm x 25.4 mm); 0.38" (9.5 mm) diameter mounting hole; 1.13" (28.5 mm) diameter recess for optional washer or bolt flange. Mounting hardware not included. Sold individually.
  • Construction MaterialRubber
  • Color / FinishBlack
  • BrandPenn-Elcom
  • Model9106
  • Part Number260-772
  • UPC844632082634
  • Product CategoryCase & Cabinet Feet
    (16 Reviews)
  • Weight0.1000 lbs.
View similar products to the Penn-Elcom 9106 Rubber Cabinet Foot 2.5" Dia. x 1" H
in the Case & Cabinet Feet product category.
Penn-Elcom 9106 Rubber Cabinet Foot 2.5" Dia. x 1" H is rated 4.6875 out of 5 by 16.
Rated 5 out of 5 by from Excellent value, very robust.These feet were made to accept a 3/8” steel bolt & washer. They form a good air-tight seal around the fastener when you tighten them down . They are completely solid rubber (no hollow casting voids), thus are very tough. They do not smell. I have put a ridiculous amount of weight on these feet (well over 250 pounds), and drug them across a tile floor with zero damage to the feet. They will leave a bit of a rubber streak on smooth tile, but it is easily wipes up with a sponge and a bit of dish-soap. I highly recommend these feet – and not just for audio applications.
Date published: 2015-08-25
Rated 5 out of 5 by from Nice ProductIs exactly as described and is a really nice quality rubber. There is no harsh smell or anything other than just the usual rubber smell that one would expect. I used carriage bolts with a washer and a nut on the inside. Worked great for my application.
Date published: 2015-06-29
Rated 2 out of 5 by from Good size, Smell TERRIBLEI bought this item a few months ago. When it shipped along with several of the other items, the whole box reeked of gas fumes. When I opened the box, my whole house smelled awful (I had ordered 16 of them). It seems these needed to 'fume out' outside in the sun and heat for a while, and that wasn't easy to do in St. Louis in December. Even after sitting out in our few sunny days these things still reek.
Date published: 2015-03-26
Rated 5 out of 5 by from Works greatBought 4 of these for the feet on my Parts Express 4cuft Sub Build, they are just perfect for this box, I picked up some M10 x 50 bolts, rubber washers, washers and lock washers and drilled the 4 holes and sizing is perfect
Date published: 2015-03-22
Rated 5 out of 5 by from Nice Large FeetThese are perfect for large subwoofers on hard floors.
Date published: 2015-01-03
Rated 5 out of 5 by from Best quality rubber feetPenn-Elcom make the highest quality rubber feet ~ hands down. These are really large feet but if you are building (or replacing) on a big bass cab or a 4 x 12 these are the ticket. They wear well and won't fall apart like some of the import stuff I used to source from a well known auction site.Penn-Elcom makes really high quality amp & cabinet handles, corners, latches, knobs, etc. You won't find better quality and Parts Express is the best on-line source I've found. If you need rubber feet this large there is nothing better!
Date published: 2014-10-16
  • 2016-02-07T06:48CST
  • co_hasreviews, tv_0, tr_16
  • loc_en_US, sid_260-772, PRD, sort_mostRecent
Could these be used as couch isolation feet for a tactile transducer install?
Asked by: Muffin Man
Yes, that is possible.
Answered by: MattW
Date published: 2015-04-08
will these be dense enough for a table weighing about 300 lbs and will a 3/8 bolt fit in the mounting hole?
Asked by: joe slim
Yes these should work fine for that kind of weight. The mounting hole diameter for this is 0.38" so a 3/8" diameter bolt will work.
Date published: 2015-03-11
What is the best way to mount these feet on at 3/4 inch MDF cabinet?
Asked by: rk1981
The most common method for mounting these is simply with 3/4" or 1" #8 wood screws.
Date published: 2014-12-31
Does this come with screws?
Asked by: ohjohnny
Mounting hardware is not included as stated in the Product Details. No screws are included.
Answered by: JimOfOakCreek
Date published: 2012-03-05
  • 2016-02-07T07:31CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_260-772, PRD, sort_recentQuestionsFirst
