Peerless by Tymphany TC6FC00-04 2" Full Range Paper Cone Woofer 4 Ohm
Brand:|Model: TC6FC00-04|Part # 264-1124
Capable of extremely accurate and lifelike sound quality, the TC6FC00-04 2" full-range speaker from Tymphany (formerly Vifa) is perfect for speaker applications that demand the smallest possible driver.
OUT OF STOCK
Due In: 10/19/2016
List Price$19.99
You Save26%
$14.80
Buy 4+$13.85
Part # 264-1124
  • Neodymium magnet and stamped steel frame
  • Patented NRSC PentaCut cone technology controls resonances and improves performance
  • Under-spider venting increases power handling
  • Half-roll rubber surround for unrestricted travel
  • Copper pole piece cap controls impedance and extends HF response
Tymphany's TC6FC00-04 brings classic hi-fi capabilities to compact music and media systems. Tymphany's patented PentaCut paper cone technology improves musicality and accuracy, and the driver's high-energy neodymium motor provides superior motor strength despite its small size. A copper cap on the pole piece controls system impedance, thereby extending the upper frequency range.
The TC6FC00-04 is ideally suited for use in flat panel televisions and sound bars, MP3 and cell phone docking stations, hi-fi speaker line arrays, and multimedia PCs.
  • Nominal Diameter2"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance4 ohms
  • Frequency Response150 to 20,000 Hz
  • Sensitivity82.9 dB 1W/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)181 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)0.03 mH
  • Mechanical Q (Qms)3.61
  • Electromagnetic Q (Qes)1.02
  • Total Q (Qts)0.8
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)0.67 mm/N
  • BL Product (BL)2.11 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.2g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)15.2 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.17"
  • Baffle Cutout Diameter2.09"
  • Depth1.25"
  • # Mounting Holes4
  • Sealed Volume0.03 ft.³
  • Sealed F3187 Hz
  • Vented Volume0.04 ft.³
  • Vented F3106 Hz
  • BrandPeerless by Tymphany
  • ModelTC6FC00-04
  • Part Number264-1124
  • UPC844632092572
  • Product CategoryWoofers
    (2 Reviews)
  • Weight0.15 lbs.
View similar products to the Peerless by Tymphany TC6FC00-04 2" Full Range Paper Cone Woofer 4 Ohm
