Peerless by Tymphany SDS-160F25PR01-08 6-1/2" Paper Cone Woofer Speaker
Brand:|Model: SDS-160F25PR01-08|Part # 264-1146
The elegant yet affordable Peerless SDS-160F25PR01-08 6-1/2" woofer is optimized for use in sealed enclosures, and is an excellent example of the quality drivers found in the Peerless Silver Line.
List Price$26.99
You Save26%
$20.00
Buy 4+$18.30
Part # 264-1146
  • Premium sculpted stamped steel chassis fits narrow enclosures
  • Coated paper cone with durable rubber half-roll edge
  • Exceptionally smooth response through the midrange
  • Great performance in compact sealed enclosures
The Peerless SDS-160F25PR01-08 6-1/2" woofer features a coated paper cone for smooth response and a well-ventilated voice coil for excellent power handling. It delivers outstanding results when used in small surround sound speakers, compact monitors, and even as the midrange component in 3-way or 4-way loudspeaker systems.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response35 to 8,000 Hz
  • Sensitivity87 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)42 Hz
  • DC Resistance (Re)7.1 ohms
  • Voice Coil Inductance (Le)0.41 mH
  • Mechanical Q (Qms)2.97
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.49
  • Compliance Equivalent Volume (Vas)1.04 ft.³
  • Mechanical Compliance of Suspension (Cms)0.12 mm/N
  • BL Product (BL)6.64 Tm
  • Diaphragm Mass Inc. Airload (Mms)13.7g
  • Maximum Linear Excursion (Xmax)6.05 mm
  • Surface Area of Cone (Sd)141 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.17", Across Flats: 6.46"
  • Baffle Cutout Diameter5.66"
  • Depth3.14"
  • Bolt Circle Diameter6.7"
  • # Mounting Holes6
  • Sealed Volume0.58 ft.³
  • Sealed F369 Hz
  • Vented Volume1.58 ft.³
  • Vented F333 Hz
  • BrandPeerless by Tymphany
  • ModelSDS-160F25PR01-08
  • Part Number264-1146
  • UPC844632092671
  • Product CategoryWoofers
    (5 Reviews)
  • Weight2.5 lbs.
View similar products to the Peerless by Tymphany SDS-160F25PR01-08 6-1/2" Paper Cone Woofer Speaker
