Peerless by Tymphany PMT Series 30N18AL04 3/4" Aluminum Dome Micro Full Range Speaker 4 Ohm
Brand:|Model: 30N18AL04|Part # 264-1153
The 30N18AL04 3/4" aluminum cone full-range driver from Tymphany is purpose-built for computer, television, micro array, and similar modern audio applications.
List Price$12.99
You Save31%
$9.00
Buy 4-9 $8.25
Buy 10+$7.84
Part # 264-1153
  • Flat, controlled frequency response from 300 Hz to 14,000 Hz
  • Designed for use as a mini full-range speaker or for line arrays when used in groups
  • Screwless, press-fit, polymer frame
  • Very low resonant frequency and Qts specifications, especially for a 3/4" driver!
The PMT Series family of micro speakers, from Tymphany, is designed for maximum full-range bandwidth, while maintaining superior off-axis response.
Tymphany built the 3/4" 30N18AL04 PMT Series premium micro transducer for computer, television, micro array, and similar modern audio applications. It features a neodymium motor, light aluminum cone, and high-temperature polycarbonate frame that is designed for minimum center-to-center mounting distance and reduced comb filtering.
A low 223 Hz resonant frequency allows the 30N18AL04 to reproduce frequencies lower than most drivers this size (250 Hz), while maintaining an average sensitivity of 81.6 dB (2.83V/1m) from 300 to 14,000 Hz. Using four drivers in a series-parallel group of four units increases sensitivity to a respectable 87.6 dB (2.83V/1m).
  • Nominal Diameter1"
  • Power Handling (RMS)1.5 Watts
  • Power Handling (max)3.0 Watts
  • Impedance4 ohms
  • Frequency Response223 to 20,000 Hz
  • Sensitivity81.6 dB 2.83V/1m
  • Sensitivity78.0 dB 1W/1m
  • Voice Coil Diameter0.71"
  • Resonant Frequency (Fs)223 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.06 mH
  • Mechanical Q (Qms)2.3
  • Electromagnetic Q (Qes)0.86
  • Total Q (Qts)0.62
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)85.16 mm/N
  • BL Product (BL)1.86 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.59g
  • Maximum Linear Excursion (Xmax)1.95 mm
  • Surface Area of Cone (Sd)4.9 cm²
  • Cone MaterialAluminum
  • Surround MaterialFoam
  • Basket / Frame MaterialPolymer
  • Overall Outside Diameter1.34"
  • Baffle Cutout Diameter1.24"
  • Depth0.59"
  • BrandPeerless by Tymphany
  • Model30N18AL04
  • Part Number264-1153
  • UPC848864014913
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.0638 lbs.
View similar products to the Peerless by Tymphany PMT Series 30N18AL04 3/4" Aluminum Dome Micro Full Range Speaker 4 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
