Peerless by Tymphany PMT Series 20N12AL04 1/2" Aluminum Dome Micro Full Range Speaker Driver 4 Ohm
Brand:|Model: 20N12AL04|Part # 264-1151
The 20N12AL04-04 1/2" aluminum cone full-range driver from Tymphany is purpose-built for computer, television, micro array, and similar modern audio applications.
List Price$6.99
You Save16%
$5.84
Buy 4-9 $5.26
Buy 10+$4.73
Part # 264-1151
  • Flat, controlled frequency response from 350 Hz to 20,000 Hz
  • Designed for use as a mini full-range speaker or for line arrays when used in groups
  • Very low resonant frequency for a 1/2" driver!
  • Screwless, press-fit, polymer frame
The PMT Series family of micro speakers, from Tymphany, is designed for maximum full-range bandwidth, while maintaining superior off-axis response.
Tymphany built the 1/2" 20N12AL04-04 PMT Series premium micro transducer for computer, television, micro array, and similar modern audio applications. It features a neodymium motor, light aluminum cone, and high-temperature polycarbonate frame that is designed for minimum center-to-center mounting distance and reduced comb filtering.
A low 359 Hz resonant frequency allows the 20N12AL04-04 to reproduce frequencies lower than most drivers this size (350 Hz), while maintaining an average sensitivity of 79.5 dB (2.83V/1m) from 400 to 20,000 Hz. Using four drivers in a series-parallel group increases sensitivity to a respectable 85.5 dB (2.83V/1m).
  • Nominal Diameter< 1"
  • Power Handling (RMS)1 Watts
  • Power Handling (max)2 Watts
  • Impedance4 ohms
  • Frequency Response350 to 20,000 Hz
  • Sensitivity79.5 dB 2.83V/1m
  • Voice Coil Diameter0.50"
  • Resonant Frequency (Fs)359 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.03 mH
  • Mechanical Q (Qms)2.8
  • Electromagnetic Q (Qes)2.41
  • Total Q (Qts)1.26
  • Compliance Equivalent Volume (Vas)0.001 ft.³
  • BL Product (BL)0.89 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.20g
  • Maximum Linear Excursion (Xmax)0.40 mm
  • Surface Area of Cone (Sd)2.5 cm²
  • Cone MaterialAluminum
  • Surround MaterialFoam
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter0.90"
  • Baffle Cutout DiameterRear mount 0.78"
  • Depth0.26"
  • BrandPeerless by Tymphany
  • Model20N12AL04
  • Part Number264-1151
  • UPC848864014890
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight0.0396 lbs.
View similar products to the Peerless by Tymphany PMT Series 20N12AL04 1/2" Aluminum Dome Micro Full Range Speaker Driver 4 Ohm
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
