Peerless by Tymphany NE315W-08 12" Subwoofer Speaker
Brand:|Model: AUBA03009-0002|Part # 264-1142
Tymphany's (formerly Vifa) NE315W-08 12" neodymium subwoofer features a sophisticated, aerodynamic cast aluminum basket that also serves as a heat sink. The driver's Pentacone diaphragm technology and high-strength neodymium magnet provide incredibly deep, clean bass fundamentals.
List Price$349.99
You Save25%
$262.63
Buy 4+$240.28
Part # 264-1142
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 2" voice coil on strong, heat resistant titanium former
  • Copper pole piece cap for reduced inductance
  • 8 ohm nominal impedance
The Tymphany NE315W-08 12" subwoofer's open cast aluminum basket design minimizes internal acoustic reflections and helps cool the neodymium motor. An additional heat sink supplements thermal dissipation. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to the motor's copper cap, which reduces inductance and extends the driver's upper frequency range.
  • Nominal Diameter12"
  • Power Handling (RMS)190 Watts
  • Power Handling (max)380 Watts
  • Impedance8 ohms
  • Frequency Response20 to 1,000 Hz
  • Sensitivity85.4 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)20 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.54 mH
  • Mechanical Q (Qms)11.72
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)5.7 ft.³
  • Mechanical Compliance of Suspension (Cms)0.45 mm/N
  • BL Product (BL)17.68 Tm
  • Diaphragm Mass Inc. Airload (Mms)140.1g
  • Maximum Linear Excursion (Xmax)9.35 mm
  • Surface Area of Cone (Sd)506.7 cm²
  • Cone MaterialWood Fiber
  • Surround MaterialRubber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter12.4"
  • Baffle Cutout Diameter11.33"
  • Depth6.19"
  • # Mounting Holes5
  • Sealed Volume1.3 ft.³
  • Sealed F345 Hz
  • Vented Volume2.86 ft.³
  • Vented F327 Hz
  • BrandPeerless by Tymphany
  • ModelAUBA03009-0002
  • Part Number264-1142
  • UPC844632092657
    (2 Reviews)
  • Weight6.1 lbs.
View similar products to the Peerless by Tymphany NE315W-08 12" Subwoofer Speaker
