Peerless by Tymphany NE225W-08 8" Subwoofer Speaker
Brand:|Model: NE225W-08|Part # 264-1138
The beautifully styled but supremely effective Tymphany's (formerly Vifa) NE225W-08 8" subwoofer employs advanced modeling techniques and premium construction to yield no-compromise bass performance.
List Price$245.99
You Save23%
$189.96
Buy 4+$175.49
Part # 264-1138
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 2" voice coil on titanium former
  • Copper pole piece cap for vastly reduced inductance
  • 8 ohm nominal impedance
Tymphany's NE Series subwoofers feature an open cast aluminum basket design that minimizes internal acoustic reflections and helps cool the neodymium motor. An additional heat sink provides extra thermal dissipation. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to the motor's copper cap, which reduces inductance.
  • Nominal Diameter8"
  • Power Handling (RMS)160 Watts
  • Power Handling (max)320 Watts
  • Impedance8 ohms
  • Frequency Response20 to 2,000 Hz
  • Sensitivity87.5 dB 1W/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)32 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.21 mH
  • Mechanical Q (Qms)8.84
  • Electromagnetic Q (Qes)0.34
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)1.77 ft.³
  • Mechanical Compliance of Suspension (Cms)0.7 mm/N
  • BL Product (BL)11.52 Tm
  • Diaphragm Mass Inc. Airload (Mms)35.9g
  • Maximum Linear Excursion (Xmax)7.7 mm
  • Surface Area of Cone (Sd)227 cm²
  • Cone MaterialWood Fiber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter8.86"
  • Baffle Cutout Diameter7.8"
  • Depth4.69"
  • # Mounting Holes5
  • Sealed Volume0.34 ft.³
  • Sealed F378 Hz
  • Vented Volume0.72 ft.³
  • Vented F336 Hz
  • BrandPeerless by Tymphany
  • ModelNE225W-08
  • Part Number264-1138
  • UPC844632092626
    (2 Reviews)
  • Weight4.35 lbs.
View similar products to the Peerless by Tymphany NE225W-08 8" Subwoofer Speaker
