Peerless by Tymphany NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
Brand:|Model: NE149W-08|Part # 264-1132
The advanced design and superior construction of Tymphany's (formerly Vifa) NE149W-08 5-1/4" neodymium speaker make it a preferred component for sophisticated audio designs.
List Price$153.99
You Save25%
$115.21
Buy 4+$105.40
Part # 264-1132
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
The Tymphany NE149W-08 5-1/4" neodymium woofer is characterized by the NE Series' cast aluminum basket—an innovative sculpted, open design that minimizes internal acoustic reflections and assists the neodymium motor's thermal management.
A coated natural wood fiber cone with a butyl rubber surround is FEA optimized for linearity of performance. Finite element analysis techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends the speaker's upper frequency performance.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)54 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.08 mH
  • Mechanical Q (Qms)8.19
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.3 ft.³
  • Mechanical Compliance of Suspension (Cms)0.84 mm/N
  • BL Product (BL)7.42 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.3g
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)85 cm²
  • Cone MaterialWood Fiber
  • Surround MaterialRubber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter5.39"
  • Baffle Cutout Diameter4.92"
  • Depth3.18"
  • # Mounting Holes5
  • Sealed Volume0.09 ft.³
  • Sealed F3113 Hz
  • Vented Volume0.2 ft.³
  • Vented F363 Hz
  • BrandPeerless by Tymphany
  • ModelNE149W-08
  • Part Number264-1132
  • UPC844632092602
  • Product CategoryWoofers
    (1 Reviews)
  • Weight1.55 lbs.
View similar products to the Peerless by Tymphany NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
