Peerless by Tymphany NE123W-08 4" Full Range Woofer Speaker
Brand:|Model: NE123W-08|Part # 264-1128
The high fidelity/low distortion Tymphany (formerly Vifa) NE123W-08 4" Neodymium Woofer utilizes advanced design and measurement technologies in combination with carefully selected construction materials.
List Price$107.99
You Save22%
$84.77
Buy 4+$77.55
Part # 264-1128
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/4" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
The Tymphany NE123W-08 4" Neodymium Woofer features an innovative sculpted, open cast aluminum basket design that minimizes internal acoustic reflections and supplements the neodymium motor's dedicated heat sink. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends high frequency performance.
  • Nominal Diameter4"
  • Power Handling (RMS)90 Watts
  • Power Handling (max)180 Watts
  • Impedance8 ohms
  • Frequency Response60 to 8,000 Hz
  • Sensitivity86.2 dB 1W/1m
  • Voice Coil Diameter1.28"
  • Resonant Frequency (Fs)61 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.06 mH
  • Mechanical Q (Qms)4.98
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.21 ft.³
  • Mechanical Compliance of Suspension (Cms)1.43 mm/N
  • BL Product (BL)5.53 Tm
  • Diaphragm Mass Inc. Airload (Mms)4.7g
  • Maximum Linear Excursion (Xmax)3.1 mm
  • Surface Area of Cone (Sd)54.1 cm²
  • Cone MaterialWood Fiber
  • Surround MaterialRubber
  • Voice Coil FormerTitanium
  • Magnet MaterialNeodymium
  • Overall Outside Diameter4.84"
  • Baffle Cutout Diameter3.86"
  • Depth2.58"
  • # Mounting Holes5
  • Sealed Volume0.05 ft.³
  • Sealed F3141 Hz
  • Vented Volume0.1 ft.³
  • Vented F384 Hz
  • BrandPeerless by Tymphany
  • ModelNE123W-08
  • Part Number264-1128
  • UPC844632092596
  • Product CategoryWoofers
    (6 Reviews)
  • Weight1 lbs.
View similar products to the Peerless by Tymphany NE123W-08 4" Full Range Woofer Speaker
